Results 1 to 10 of 10
Thread: 4 channel amp
    markER717's Avatar
    markER717 is offline Un-Donated Member
    1990 3.8L VN Calais S1
    Jun 2009
    Geelong, Victoria
    Default 4 channel amp
    Well I have thourght about it a bit and I think i may just upgrade my fronts speakers too but if I had an amp to run the 6x9s would it blow my 4" fronts? or if I had the power leaned more to wards the back speakers would it be bettter?
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Are you reffering to the 4 inch factory dash speakers? if so, yes you could blow them. After market 4's, well it's not uncommon to find decent 4 inch coaxial, or even split system speakers, rated to 60RMS, or even higher, depending on how much your willing to spend. By leaning, (or fading as it's known) to the rear, all that's going to do, is draw your sound stage back.
    Seriously dude, of you haven't already purchased the 6x9's, don't do it!!! In order for your stereo to sound good, the sound stage MUST come predominately from the front. You wouldnt go to a concert and stand there with your back turned to it would you?
    Trust me mate, i've been down the path, i've even had a set of 4's, 6's, 6x9's, and a sub, all at once. And it wasn't cheap gear either, but i ripped it out, put good splits in the front, and a properly amped sub, in a speciffically built enclosure, and i tell you now you can't even compare the two !!!
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    ^^^What he said. I'm sick of writing it out every time
    Oh, and it isn't too hard to put VR/S door pods on your VN and you can run 6/6.5" speakers in the front
    Someone recently, maybe even HCVP put some good looking fibreglass? pods on the door trims instead of the holden ones so thats an option as well
    markER717's Avatar
    Jun 2009
    Geelong, Victoria
    I only got the 6x9s because i can't afford a good system at the moment. I am thinking of putting some pioneer 4" in the fronts but I will eventually uprade to 6" splits with vr door pods but all in good time I just neeed something decent because atm those 4" factories are actually all i have -.-
    Mar 2009
    Cairns White Rock
    [QUOTE=Philthy;1210802
    Someone recently, maybe even HCVP put some good looking fibreglass? pods on the door trims instead of the holden ones so thats an option as well[/QUOTE]
    These ones?http://forums.justcommodores.com.au/...-photo0224.jpg
    The Factory VR VS pods look awful in a Blue VP interior, no way was i going to have them. I just gotta get some rear map pockets now from a VQ, then modify the remaining door trim to suit them, for a near factory look
    Pods in question, were just the 6 inch aerpro versions, carefully sounded out to accomodate a 6.5 inch speaker, and an MDF spacer attached to the base, to eliminate any clearance issues, then re-trimmed to suit..
    Mar 2009
    Cairns White Rock
    But yeah mate, if all you have to work with is the 6x9's, and an amp, then by all means put them in. I guess i'd rather have amped rear speakers on there own, than the factory dash ones. A few to keep in mind though, there's no drop in location for a set of 6x9's on the rear shelf(unless you can get them to fit above the factory rear cutouts, some will, some won't). Otherwise, you will need a spacer to start with, and then you will need to cut the pressed fibre shelf ( carefull, their very fragile, i went through 3 getting it right)
    Attached Thumbnails Attached Thumbnails 4 channel amp-photo0011.jpg   4 channel amp-photo0012-1.jpg
    markER717's Avatar
    Jun 2009
    Geelong, Victoria
    Well I was thinking if they dont fit to make like plat forms and mount them else where and tilt them to face the car so sound doesnt hit window.
    Mar 2009
    Cairns White Rock
    those spacers in the pictures i used are only about 20 bucks, and just screw down with 4 screws. You can get angled one's aswell, but again it depends on the depth of the speaker basket.
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Just something to bear in mind with an "exposed" system in an older car, is that it will be a thief magnet. Careful where you park if you have the shiny bits in plain view like that.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    markER717's Avatar
    Jun 2009
    Geelong, Victoria
    Calais alarm system. + Deadlocked when in bad areas.
  1. Let's fix Channel Nine
    By sfordham in forum The Pub
    Last Post: 01-07-2008, 12:19 PM
  2. Channel Ten
    By minux in forum The Pub
    Last Post: 03-11-2007, 03:57 PM
  3. V8s go to channel 7
    By Troy711 in forum Motorsport
    Last Post: 05-02-2007, 10:19 PM
  4. 5 channel amp
    By commyvx in forum Car Audio
    Last Post: 08-08-2006, 01:51 PM
  5. Amp channel
    By jamiekratin in forum Car Audio
    Last Post: 06-07-2006, 04:27 PM
