Results 1 to 6 of 6
Thread: removing headunit VX
    VX/VY Executive
    Mar 2009
    Default removing headunit VX
    hey, im sure this has been asked before, but i couldn't seem to find it using search.
    im wondering how you remove the stock headunit from a VX?
    cheers.
    vp calais
    May 2006
    adelaide
    there are tools on ebay, failing that long thin nails inserted into the 4 small holes in the corners of the unit and it will slide out
    | evaN |'s Avatar
    | evaN | is offline mmm bass
    VT
    May 2006
    SE Melbourne
    i used an old coat hanger to create two 'U' shapes. There should be two holes on each side. Slide the 'U' shape tools you just made into it and it should just slide out.
    VX/VY Executive
    Mar 2009
    awesome, thanks guys.
    do they all need to done at the same time or can u do them individually?
    also, how long are we talking with these nails?
    vp calais
    May 2006
    adelaide
    bout 3 to 4" nails. all need to be done at the same time.
    once u get the unit out u can see y there are small hooks holding the unit in and by putting the nails etc into the holes you are pushing the clips back so u can slide the unit out
    VTCommy is offline up tha commodores!
    VT Executive S2
    Dec 2008
    Streaky Bay
    I found that the coat hanger trick is the best method
  1. removing headunit
    By pac3y in forum Car Audio
    Last Post: 17-01-2009, 11:36 AM
  2. Old headunit versus New Headunit
    By SVZ_MY06 in forum Car Audio
    Last Post: 28-04-2006, 11:12 AM
  3. having trouble with removing headunit
    By Brycestro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2006, 11:33 PM
  4. low pitch hissing sound after removing headunit
    Last Post: 17-02-2006, 11:32 PM
  5. Removing stock headunit
    By CLE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-11-2005, 01:09 PM
