Results 1 to 7 of 7
Thread: Amp Problems
    VS Equipe
    May 2009
    Default Amp Problems
    hey all.
    i am having a few problems with my amps
    look at the diagram below
    ok amp 1 goes into protection mode when i turn amp 2 on
    i have tried swapping the remote wires around but the same problem
    i dont know wat else to do
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    All looks fine there, what are each amp running?
    Is it possible to swap the speakers / subwoofers over from one amp to another?
    EDIT: Also try swapping over the RCAs or inputs.
    150db in a commodore =
    VS Equipe
    May 2009
    thanks for the quick reply
    yeah tried that mate but the same amp is going into protection
    all te power wires and remote wires are running tied together
    just wondering if i should seperate the remote wire from the power cables?
    VY Berlina V6 / R31 Skyline
    Dec 2008
    i always though to run power on a seperate side to remote/rca/speaker cable and i have run two amps with no problems using this method, maybe worth a try?
    Cheers mate.
    '96 VS II SS
    Mar 2009
    Quote Originally Posted by Crossy_014 View Post
    hey all.
    Make sure your speakers or at least one of them are not going to earth!
    It's so easy to have a lug at the mounted speaker touching the body of the car.
    Good luck.
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Seperating the power / remote / RCAs wont fix an amp going into protect.
    Monaro6 maybe right there about a speaker cable shorting etc.
    So you have tried swapping over the speakers / subwoofers from the 1st amp to the second?
    VS Equipe
    May 2009
    thanks for the help everyone
    i ran a cable straight from the battery to the remote wire and it runs fine now
    so i will put in a relay tommorrow
  1. Signal Problems Aand LPG Problems
    By reyyan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 08:33 AM
  2. vn problems
    By BURK_POP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-03-2007, 09:33 PM
  3. vl aut problems
    By 308commodore in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-03-2007, 07:01 PM
  4. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  5. VL Problems
    By SLE-EZY in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-07-2006, 08:42 PM
