Results 1 to 12 of 12
Thread: Fitting 6x9s into a VN
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Default Fitting 6x9s into a VN
    I'm gonna be going out to buy a set of Kenwood 6x9s very shortly, and wanted to know how I would go about mounting them in the parcel shelf of a VN commodore.
    Would I be cutting a hole in the parcel shelf? Or using spacers? If I were to use spacers, which ones would I get? And where from? Considering that the window on the VN is farely close
    Quote Originally Posted by PaRaDoX View Post
    btw do you plan to fly? looks like you have a gauge for everything, refreshment levels gauge, washer fluid temp? penis pump vacuum? *runs and hides*
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Why is "power" so important? Do you have a little dick?
    People are too obsessed with how much "power" their car makes....it doesn't make power, it produces torque, from which this mythical "power" figure is calculated.
    VP Exec
    Mar 2009
    Melbourne, bayswater
    6x9 in a VN parcel shelf realy dont mix. I wouldnt cut a hole in my parcel shelf. I tryed useing spacers in my VN but it didnt happen, the speaker keeped on hitting the window. As ugly as it is... you can put them in boxes and then just mount them on top of the parcel shelf.
    Or just go 6x5 like i did. fitted perfect for me.
    -Junior-'s Avatar
    -Junior- is offline <-- Back to Back in 2010
    vn auto
    Apr 2006
    S.W. Sydney
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Allrighty, you have 2 options basically.A hole will be required in the parcel shelf for each speaker, and you can choose to mount them in and above the sotck rear 6 inch hole (once the parcel shelf is removed, you'll see 2 holes which are spot welded up, if your's wasn't optioned with rear speakers) Otherwise, you can mount them in the centre of the shelf, closer to the cabin. Whether you will require a spacer or not, will depend on the overall mounting depth of the speaker basket, but most likely will require one. You can get spacers in different shapes, heights, angles, ect.. Most commonly you will see an angled spacer used, when mounting above the stock rear location, generally being as it's so close to the rear window it would cause clearance issues otherwise.http://forums.justcommodores.com.au/...-photo0011.jpg here is a set i installed in a VP,http://forums.justcommodores.com.au/...o0012-1.jpgthe spacers used here were from AERPRO.Speakers And Spacers - AERPRO Car Audio Accessories if you have a look on their website, they will give you a list of stores in your area which stock their products.
    If you have any questions, let me know, and i'll see if i can't help you through it...
    VR Commodore V6
    Sep 2008
    Sydney NSW
    To do what was done in those pictures, basically how big of a whole will need to be cut into the parcel shelf?
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Mar 2009
    Cairns White Rock
    The hole you'll need to cut, does not have to be the size of the basket. Because you are raising the speaker with a spacer, the hole basically only has to accomodate the magnet, and in some cases, a small amount of the basket. Also, with these pressed firbe parcel shelves, they are very fragile ( i went through 3) by the time you cut a hole, attach a spacer, a put a speaker in, your not left with a whole lot in terms of strenght, with the shelf, so becareful, and take your time.
    Trial fit your spacer,to the parcel shelf once its out, without screwing it down, and trace around the inside if it,then remove the spacer and get your speaker. Find the centre of the circle you've just traced, and place the speaker there, with the magnet being in the center. Now trace around the magnet. The hole from the magnet will be the one you'll need to cut. Once it's cut, you can trial fit the speaker with the spacer, and see if there's sufficient clearance. If not, then you'll just have to expand the hole a little more until it suits.
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Are you serious? So this isn't gonna be a very simple job?
    I might just NOT bother >_<
    92 VP Calais 3.8
    May 2006
    Gold Coast
    Its simple, just gotta cut a hole, screw down the spacers n bolt in the speakers.
    The most time will be spent on measuring out ur distances so its all even.
    I think i put sum in in around a hr, its much harder to get 6.5's in the factory position as its soo close to the rear window u dont have much room to work with even with the parcel shelf out.
    Having them back from the window makes it soo much easier.
    Best to pop out the shelf tho, jst to be sure its not too far back or it will hit the metal, alternativly look in ya boot to try guess where the ridge starts.
    ________________________________________
    Mar 2009
    Cairns White Rock
    Quote Originally Posted by crazybiker View Post
    Well it's a fairly simple job, you have no amps, no RCA's, no firewalls to navigate through ect... A proper installation is the key to any good sounding stereo. Just take your time with it, and you will apreciate the results...
    VS 97 Series II
    Oct 2007
    Whalan, N.S.W
    Are you running a sub??
    My new ride with some upgrades.
    www.teamfusion.info
    Head unit: Fusion CA-CD500 Front Speakers: Fusion PP-CM650
    Rear Speakers: FusionPP-FR6520 Subwoofer: Fusion PP-SW120 Amp For Front And Rear: Fusion PP-AM120040 Subwoofer Amp: Fusion PP-AM300010
  1. vp rear 6x9s
    By joshooaahh in forum Car Audio
    Last Post: 27-03-2009, 08:09 PM
  2. VT 6x9s
    By happyjag2006 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-11-2008, 02:40 PM
  3. spacer for 6x9s
    By adams vn in forum Car Audio
    Last Post: 15-09-2006, 03:01 PM
  4. 6x9s in a VT
    By Sebastian in forum Car Audio
    Last Post: 29-07-2006, 12:31 AM
  5. 6x9s in a vr
    By not_just_any_vr in forum Car Audio
    Last Post: 18-07-2006, 08:14 PM
