I cant find another thread that answers my question so if anyone does know where can you please point it out to me, thank you.
Ok, all i was wanting to know is how to get to the factory subs to remove them in my vz clubsport. I'm thinking the grill on the parcel tray is just hooked in by clips so i would just need to hook onto the grill carfull around the edges and pull it out gently? Or is there more to it? I'm just worried that if this isnt correct i will end up damaging the grill, can someone please help, would be muchly apriciated
Ray
Remove your parcel shelf,
Take the seat out, takes about 5minutes, parcel shelf has a couple of clips, You wont fit the 8" subs through the grill space.
From memory the seat if u look where it sits against the floorpan, on Vt-VZ i think there may be pull tabs? Pull those it'll release teh base, & then the 2 side bits are held in by 1 10mm bolt eachside as far as i remember.
Once removed undo the couple of clips an remove the parcel shelf
First time, about 30mins work, Not too hard either.
MaT
Originally Posted by garth
Hey matt thanks a million for the info mate
No probs bud!
Goodluck
