Results 1 to 14 of 14
Thread: dvd screen not working
    vy
    Jul 2009
    Question dvd screen not working
    pioneer dvd double din unit 7 in screen
    wired it up and earth hand brake wire no success
    put it to the amp remote wire on head unit no sucess
    i can u wire the unit to by pass handbrake and be permantly on it a vy clubby sport
    cheers nathan
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    What?
    Does the head unit work at all?
    If the head unit works, what is the problem you're having? No picture at all? Warning on the screen?
    This isn't kindergarten, give some useful info.
    vy
    Jul 2009
    Coast_Calais is offline sick of the idiots here
    varies
    Jul 2008
    gone
    what warning? "don't use while driving?" if so, the rear monitor cable hasn't been connected correctly..
    Does the head unit work?
    A little more info, would help us, help you....
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    What model?
    Every Pioneer model I've used would work if you touched the green wire (handbrake wire) to ground. If it's not working, you mustn't have found a proper ground.
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    lol its clear your problem is with the earth for the handbrake.
    Was the handbrake off when you tested it? Then thats the problem. Handbrake has to be on.
    Or do what I did and wire the handbrake caution wire streight to the body
    vy
    Jul 2009
    model no is avh p4100dvd
    touching earth wire on bare floor pan under console has seen picture no 4 times but warning comes back on the screen it must need a toggle switch i m guessing
    cheers nathan
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    "has seen picture no 4 times but warning comes back"
    In english?
    The picture comes on but you still get the warning?
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    you have to stop the car, pull the hand brake up, pull it down and pull it up again and push ok....accept or watever....
    There is no such thing as stupid questions, Only stupid people.
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Quote Originally Posted by TrikkBen View Post
    If thats the case then a toggle switch on the wire would work if the wires connected streight to the body?
    That way passangers can watch dvd's while the cars moving.
    varies
    Jul 2008
    gone
    argh, if the handbrake trace is earthed, it will work at all times without requiring input as a warning msg should not be displayed if wired correctly. (have u checked your earth with a test light?)
    My alpine works fine, without any prompts, and there are three "safety" wires, footbrake, handbrake and rear monitor trace. All are earthed permanently, and works just fine...
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    Quote Originally Posted by Ozzie View Post
    Thats what i did
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    i would presume the manual would have listed how to wire up and get the unit working..
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    Quote Originally Posted by ephect View Post
    No one reads them anymore, duhh.... lol
  1. traction control light on dash not working... except for the fact that it is working
    By redcv6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-07-2009, 10:41 AM
  2. Black screen after bios screen
    By TVR-190 in forum The LAN Lounge
    Last Post: 26-05-2009, 12:10 PM
  3. Replies: 3
    Last Post: 13-10-2007, 01:52 PM
  4. laptop screen into dvd screen?
    By tweakt in forum Electrical Wiring / Questions
    Last Post: 10-06-2005, 09:48 AM
  5. TV screen for VN!
    By hypo_v6 in forum Car Audio
    Last Post: 18-01-2005, 08:19 PM
