Results 1 to 7 of 7
Thread: How Do You Remove The Speaker Covers On a VS SIII ?
    2000 VS Ute 5 Speed
    Oct 2008
    Western NSW
    Default How Do You Remove The Speaker Covers On a VS SIII ?
    I want to replace my old speakers with some new ones, but i can't seem to get the covers off to get to the speakers. On the drivers side, there is only 1 screw, and i took that out but then when i pull the cover, it is still holding on to something, it feels like it will snap if i pull it any harder.
    Do i need to take the whole door cover off? Or is there just a little clip or something that is holding it in there, am i just pulling at the wrong spot?
    Any help would be great!!!
    Thanks
    VY SS
    Jun 2006
    Albany
    2000 VS Ute 5 Speed
    Oct 2008
    Western NSW
    Quote Originally Posted by axemurderer101 View Post
    you need to remove the whole door cover
    Ok, thanks very much!
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Vy Sv8
    Jun 2009
    I would write one up, but I'm a slow typer and by the time I finish it 2 people would already have done it.
    Vy Sv8
    Jun 2009
    As Follows:
    * Remove the screws along the bottom of the speaker pod
    * Remove the little bit of plastic in the centre of the door handle
    * Remove the 2 screws retaining the door handle and remove the door handle
    * Remove the air vents (still dont really know an easy way to do this... just pry with a flat blade screwdriver with a cloth over it so you don't scratch your trim)
    * Remove the screws retaining the air vent holder thingy and remove it.
    * Using a little piece of stiff wire with a tiny little hook on one end, pull the red tab on the door lock towards you and lift the lock off the control rod
    * Using either a rag and a lot of cuss words or a tool you can buy from supercheap for $10 to remove the window winders. If you peer behind the handle you will find that the winders are held on with a spring clip in the shape of the 'ohm' symbol. In my opinion it is 10,000 times easier to just go to supercheap and buy the window winder removal tool.
    * Unless I've forgotten something, you can now give the trim a firm pull and it will come away from the door.
    Sounds harder than it is just give it a try.
    Stolen from another thread.
    2000 VS Ute 5 Speed
    Oct 2008
    Western NSW
    Cheers guys, thats a great help!!
  1. VX Speaker Covers
    By miss-vx-purrrfect in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-05-2009, 09:07 PM
  2. Where can I get backseat speaker covers?
    By Fritz_ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-11-2006, 06:31 PM
  3. dash speaker covers?
    By Hector martinez in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-05-2006, 11:10 PM
  4. Speaker covers
    By Dayvo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-10-2005, 06:19 PM
  5. Speaker Covers
    By WeeMan in forum Car Audio
    Last Post: 05-03-2004, 10:24 PM
