Results 1 to 5 of 5
Thread: How to put perspex into false floor
    VS SS COMMODORE S2
    Feb 2009
    Kingaroy, QLD
    Default How to put perspex into false floor
    Hey guys, im doin my own install in my ride, and im puttin in a raised false floor, i wanna put the amps under there and put perspex windows in it to show off the amps, the floor will be carpeted and im unsure how to put the perspex in.
    VY Berlina V6 / R31 Skyline
    Dec 2008
    hey mate
    are you more or less building a box as the false floor? If so, cut away some of the mdf between two rails of the box and put the perspex in there?
    VS SS COMMODORE S2
    Feb 2009
    Kingaroy, QLD
    Quote Originally Posted by sweefu View Post
    hey mate
    yeah mate thats wat im doin but im goin to carpet it, but im not sure how to carpet it with the perspex recessed in there. if that makes sense
    D-Man's Avatar
    D-Man is offline All over it...
    99 VT Calais II v6
    Aug 2008
    Melton, Victoria
    cut out the hole in the mdf, carpet it up so the edges around the hole dont show etc, turn it over so the bottom is face up. put your perspex over it (i assume it's already measured to fit - if not measure it up and cut it larger than the hole.
    place your perspex over the hole and then pre drill your holes a couple sizes smaller and countersink your holes. get screws large enough into the mdf and through the perspex but not go through the mdf.... clearly
    screw it in and then you should be good. if you want the perspex flush with the carpet... then dont do what i just said. im not sure just yet how that gets done.
    also when carpeting follow this from about the Kwik Grip down...HOW TO replace headlining - Very detailed
    or there is a slightly better version about 2 pages in saying to stage it. as in do 30 or so cm at a time so you dont have bubbles or whatnot.
    Quote Originally Posted by danja View Post
    PS. All girls are the devil. It's science.
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    The easiest and cleanest way i would do is as follows:
    Make the "Floor Piece", ie, the large top section to your box.
    Cut the viewing window you want out of your "Floor piece" section.
    Get a piece if perspex that is at minimum 4 inches bigger the whole way around your cut out in the floor piece
    ** There is a few ways you can go here.
    1. If your cutout is quite small in comparison to the floor piece, you will want to fill around the perspex (as its expensive and you'll see why)
    --> Find some mdf that is the exact same thickness as your perspex
    --> using your floor piece and perspex, make a replica of your foor piece out of the mdf (using thinner perspex here is a good idea) The floor piece cutout is one size and the filler piece cutout is another size to take into account the 4inches of buffer
    --> Glue your perspex to the floor piece, then glue your "filler cutout" to the floor piece.
    You will now have 2 layers of equal height which your can cover in carpet to hide the perspex overhang.
    Another way is to follow the above instructions but instead of making a "filler piece" cut some "at length" strips of about 1-2 inches and border your floor.
    Then, using a thin piece of mdf cut out your desired window size again and then cover the whole lot (like a sandwhich) so you have these layers:
    1 (bottom) floor piece
    2. Border edge and perspex window
    3. Top cover piece with cutout for window
    Then just carpet it!
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
  1. Searching For A False Floor Wall Boot Enclosure, Anyone Help?
    By social in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-04-2009, 09:02 AM
  2. Wirinng 2 Amps N False Floor
    By MUNTED6 in forum Car Audio
    Last Post: 03-05-2007, 03:00 PM
  3. Mounting Amps under false floor
    By Brycestro in forum Car Audio
    Last Post: 24-03-2006, 11:36 AM
  4. Perspex Windows
    By saint_matrix in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-06-2005, 12:26 PM
  5. false boot floor
    By chevy_big_block_bro in forum Car Audio
    Last Post: 20-02-2005, 10:51 PM
