Results 1 to 11 of 11
Thread: stereo works WITHOUT the fuse in
    VR Commodore Acclaim
    Jul 2009
    Launeston
    Angry stereo works WITHOUT the fuse in
    So, I recently bought a VR Commodore with a VDO Dayton stereo (CD 4203) in it, of which I have yet to get sound out of - that's another issue I'll have to ask about. Lately the battery has been running flat and the mechanic said 'it's probably the stereo.' So I took the fuse out, and the thing still powers up! It went back to the mechanic but he couldn't figure out how to disconnect the stereo.
    My question is...should I try to remove all associated dash parts (using the info I found on here) and disconnect it myself, or pay someone lots of money to do it for me? And then with all the dash parts pulled out, do I get another stereo or see why this one won't work?
    *edit*
    Someone came around for a look and found that there is another under dash fuse for slot 7 that is for the central locking - but ALSO feeds the stereo. Taking that one out killed the stereo, and the locking mechanism.
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    define fuse:
    1. OEM Fuse under steering coloum
    2. Fuse from the back of the unit itself
    If 1. then its likely that it wasn't wired into the OEM wiring like you think and thats why its still working (im betting the farm on this one)
    if 2. you have a faulty head unit... end of story.
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Which fuse does it work without?
    There will be one in the back of the headunit, and one under the dash cluster for stereo/cigarette lighter.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Azk has the faster fingers lol.
    D-Man's Avatar
    D-Man is offline All over it...
    99 VT Calais II v6
    Aug 2008
    Melton, Victoria
    what about the fuse close to the battery....
    i wouldnt imagine you took that out.. but just to be sure.
    not the one under the steeringwheel or in the back of the unit but the one under the bonnet. inside the engine bay
    Quote Originally Posted by danja View Post
    PS. All girls are the devil. It's science.
    May 2005
    .....SE Burbs
    Quote Originally Posted by Noodl3s View Post
    There is no fuse there for that... there is no point pulling out a top level fuse. Thats like disconnecting the battery and going, oh look it stopped... you need to pull the lowest level fuse out and work your way up...
    aZk.
    Wanted to buy:
    3. T5 VB Gear Box
    VN SS
    Jun 2009
    If the stereo is wired correctly it will get it's main power from the fusebox via a fuse.
    Most people just use the original stereo power wire to power any replacments stereo's meaning the original stereo fuse is still in use but not always.
    But, even if they have put in a new wire (fused or not) there should be no reason for the unit to drain the battery.
    I'd be checking other stuff. The boot light is a common cause of battery drain. The glovebox light as well. It's they are not turning off when you close them they can drain the battery.
    A lot of earlier Holdens used to have trouble with the clocks. A fault in the clock would cause the battery to drain if the car wasn't started for a couple of days.
    You need to find out where the stereo gets it's power from. It shouldn't be hard. Get under the dash with a torch and see if you can trace the wire.
    Failing that you're going to have to remove the stereo and unplug it.
    Hopefully if they've run a new wire it will have an inline fuse in it. If not, put one in anyway. Better than having a fire under your dash.
    ryno_vrx's Avatar
    ryno_vrx is offline Donating Member
    VR HSV enhanced Berlina
    Nov 2008
    Mirani
    i'm betting the stereo is wired directly up to the battery, i know a few people that do it that way for some dumbass reason
    whats the difference between my missus and my blower??
    well they both whine but the blower actually puts out
    Jul 2009
    Launeston
    Quote Originally Posted by azkwazere View Post
    define fuse:
    aZk.
    I took out the 7.5 amp fuse from under the steering wheel (slot 13.)
    Jul 2009
    Launeston
    Quote Originally Posted by Munromad View Post
    The boot light is already disconnected - battery drain might be why.
    This one doesn't have a clock
    And I can't get under the dash to find any wires. Trust me, I tried.
    I'll check the glovebox light though.
    May 2005
    .....SE Burbs
    Quote Originally Posted by vrdevilcar View Post
    Most people when they wire in a head unit will do it properly and use the existing wiring...
    others will run their own and bybass stuff.. including fuses.
    Without looking at the car its hard to say but i would suggest to you that you take your head unit out and snap some pics for me..
    aZk.
    Wanted to buy:
    3. T5 VB Gear Box
  1. nothing works
    By bigneilsen in forum Car Audio
    Last Post: 25-10-2008, 09:46 AM
  2. VX headunit works and doesen't works
    By kaishiz in forum Car Audio
    Last Post: 13-09-2007, 01:38 PM
  3. melted stereo fuse help please
    By hoon1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-11-2006, 09:37 PM
  4. stereo and dash light fuse keeps blowing
    By V8commodore_chick in forum Electrical Wiring / Questions
    Last Post: 21-07-2006, 02:03 AM
  5. Car stereo setup keeps blowing amp inline fuse
    By veeque92 in forum Car Audio
    Last Post: 17-08-2005, 01:36 AM
