i am istalling two amps under a false floor, i will obviously need to put a fan or two in there, just wondering what type of fans everyone uses and how they go about installing them.
Andrew
Use two fans, one on either side, fans are directional so put one sucking air in on one side and the other pulling the air out on the other side. Something like whats below works good, just make sure you get ball bearing versions as they last much longer.
50mm 3 Wire 12V DC Ball Bearing Fan - Jaycar Electronics
150db in a commodore =
Dick Smiths, pc supply / repair stores too i suppose.
Make sure they're 12VDC![]()
great, thanks for your help mate. (no jaycar stores where i live, but there is a Dick smith)
the ball bearing fans are much quiter too![]()
