Page 1 of 2 12 LastLast
Results 1 to 25 of 39
Thread: hookinh up new jvc headunit
    Vx S pack m5
    Sep 2007
    keilor down, vic
    Default hookinh up new jvc headunit
    gday guys I have got a new jvc headunit to put into my vx. I also got one of those aeropro connectors. Is it just a simple matter of matching the colour wires between the aeropro connector and jvc connector?
    thanks
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    use the jvc manual for the wire outputs, and u'll need a VX stereo wiring plan (manual) if you have it. then yes just match the wiring on both ends of the aeropro connector, not so much the colors .
    Sorry i cant help you with the VX audio wiring diag, dont have one for VX.
    Vx S pack m5
    Sep 2007
    keilor down, vic
    Vx S pack m5
    Sep 2007
    keilor down, vic
    sorry but does anyone know if you can buy jvc plug straight to holden vx type plug for the headunit?
    Vx S pack m5
    Sep 2007
    keilor down, vic
    iv been on the aeropro website and iv seen what I need although this connector APP061 | Aerpro ISO Connector to Suit Holden Commodore VR-VS says vr to vs and there is nothing for later modles do you think il be able to use this?
    thanks......
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    as long as the plug looks the same for the vs plug to ur vx plug then u can purchase and use this to plug into the stock plug. then just wire in/solder the ends of that plug to the stereo wiring. if u cant find a connector for the JVC, u'll have to cut the stereo plug so u can solder it in. if that makes sense
    Vx S pack m5
    Sep 2007
    keilor down, vic
    thanks not sure if you knew what I ment though I wanted to connect my new headunit without cutting/ soldering any wires with the use of aerpro harnesses. Went into jb and told the guy I wanted to connect my headunit without cutting/soldering any wires and he says there is no way without atleast soldering wires which is crap becuase I was just on the aerpro website and they sell the harnesses that let you connect to any headunit without soldering. anyway me being me I took the nobs advice at jb and brought the iso plug that connects to the stock holden plug then I just need to soldier wires onto the headunit cable. I'm sure il have a few hickups along the way.
    1st question is Do I have to make my own earth for the headunit or can I use the existing earth wire in the stock wiring harness?
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    u can use the existing earth thats no problem ok let me see if i can explain my self better. the way you have described it
    Quote Originally Posted by Simonn View Post
    this is the way to be.. if u dont wanna go this way, the below explaination is another option using a patch harness.
    vx audio loom connects to the areopro connector lets call this end, end1.
    the only other way to have a patch harness so u purchase another matching plug&socket. one end of the harness u solder/attach to end2 of ur areopro connector.
    the other end of the harness u connect/solder/attach to the headunit wiring.
    i assume that the headunit has barewires and no plug at the end of the wires? (forget the plug on the back of the hedunit itself) if so use the patch harness. it may be a bit bulky but will be ur best bet so u dont have to cut anything
    Vx S pack m5
    Sep 2007
    keilor down, vic
    thanks for that mate makes sence. although about the earth on a peice of paper that came with the headunit it says to connect the ground to the mettalic body or chassis of the car? Do people with new headunits usally dont do this?
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    It's really up to you how you earth it, I earth it To Chassis & The loom. I know people that just earth to loom, Works fine.
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    up to you, its more reliable to do it to the chasis, i have done it to the chasis. but loom works fine too
    i wasnt clear headed before.. sorry mate
    Vx S pack m5
    Sep 2007
    keilor down, vic
    np thanks man, I went to autobahn now and got the vt plug to the black and brown plug. then got another that goes from the brown black to jvc plug for the headunit. Although the the acualy plug that goes into the headunit is too big for my jvc headunit I assume my new headunit was old stock with a differnt type of plug. what should I do now? maybe I should just return these harnesses and do it the hard way with the original harness I got.
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Sounds like your trying to really get an easy way out.
    Make up a patch loom.. As Ephect has previously stated an explained, Re-read the thread please.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    can u post up pics of both plugs n harnesses. What im thinking is if the harnesses are cheapish then hack them up if they dont fit.
    post up pics n that will give me a clearer understanding maybe even the plug at the back of ur jvc and the plug with wires that came with the headunit.
  15. #15
    Vx S pack m5
    Sep 2007
    keilor down, vic
    Quote Originally Posted by HoZy View Post
    well dir. why would I want to have to solder wires together when I could of used a plug and play harness?
  16. #16
    Vx S pack m5
    Sep 2007
    keilor down, vic
    Quote Originally Posted by ephect View Post
    I should have some photos up by tonight,
    thanks
  17. #17
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Would of taken 5mins to solder up a patch harness...
    You waste more time thinking of what to post to make things easier.
  18. #18
    Vx S pack m5
    Sep 2007
    keilor down, vic
    well sorry for not knowing how to mate,I'd rather take some more time in posting questions than solder it all up and then finding out it dosent work.
    Heres the photos ephect. Can you see one of the white plugs has some more pins in it not sure which one I should use.
  19. #19
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Where is the image of your orignal JVC harness? For YOUR headunit.
    You have 2 VT harnesses pictures & 1 older style JVC plug.
  20. #20
    Vx S pack m5
    Sep 2007
    keilor down, vic
    thanks for that. So is that the older jvc plug? The guy at autobahn recons its the new type. not sure thats all they had. heres a photo of the jvc plug
  21. #21
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Click image for larger version.
    JVC manual should say what wires are what, EG: Speaker wire coloring etc.
    So basing it on that, I'd use the lower VT Connector, An start joining wires.
    The colors on the aerpro wiring harness for speakers, I am unsure about, I've never ran speakers from a headunit. So i've never wired them up.
    Should say on the aerpro packaging.
    WHAT MODEL HEADUNIT DO YOU HAVE, I'LL MAKE YOU UP A WIRING DIAGRAM TO GET IT PERFECT.
  22. #22
    Vx S pack m5
    Sep 2007
    keilor down, vic
    thanks, No the plug cannot be dremeled they are completly different.
    The aerpro pack has nothing on speaker wire colours do you think ill just be able to go off this VK-VZ Stereo wiring colours.
    thanks heaps man
  23. #23
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    What is your headunit? i'll make u a custom diagram. I need Model of it, So its a JVC ? What....
  24. #24
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Aerpro Harness
    Back Right:
    Purple
    Purple Black line
    Back Left:
    Green
    Green Black line
    Front Left:
    White
    White Black Line
    Front Right:
    Gray
    Gray Black Line
  25. #25
    Vx S pack m5
    Sep 2007
    keilor down, vic
    ok iv started hooking wores up but I'v found 2 wires which look like there for the antenna on the jvc plug (from my headunit) one is a dark blue and the other is blue with white stripe. The wire with the white stripe im pretty sure is the amp rem wire but it says power antenna on it aswell what is it for?
  1. What DVD headunit?
    By DUK13Y in forum Car Audio
    Last Post: 10-05-2009, 02:47 AM
  2. Headunit help
    By apoc585 in forum Car Audio
    Last Post: 26-10-2008, 08:33 PM
  3. help please with headunit
    By cpbait in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-09-2007, 09:41 PM
  4. Old headunit versus New Headunit
    By SVZ_MY06 in forum Car Audio
    Last Post: 28-04-2006, 11:12 AM
  5. headunit in VK
    By Shifty1 in forum Car Audio
    Last Post: 01-07-2005, 03:36 PM
