Results 1 to 16 of 16
Thread: how do i wire 4 inputs on the sub with 2 wires?
    vz ss ute
    Feb 2009
    Default how do i wire 4 inputs on the sub with 2 wires?
    the wire on the right is positive hand the wire on the eft is negative... what to do?
    im sure somebody here can help me asap
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by surfy31 View Post
    Thats a DVC (Dual Voice Coil) sub. Depending what amp your planning on hooking it up to depends how your wire the sub (parallel, series). Post the model number of the sub and amp and someone here will be able to help you more.
    Power is measured in DECIBEL
    Fonzie's Avatar
    Fonzie is offline Just lost the game.
    300zx 2+2 Targa
    Aug 2008
    Gippsland, Victoria.
    Dual voice coil sub... Someone might want to confirm this, but I think some subs automatically bridge them if you just connect the left and right most terminals... Or you may have to wire them up in series or parallel? Check the instructions that came with the sub.
    Edit: Damnit was beaten to it.
    Quote Originally Posted by Philthy View Post
    ....man, I love how white your car is
    vz ss ute
    Feb 2009
    thats guys dont go anywhere!
    im using a 1000w monoblock amp for two of these. 10" alpine type s ( sws-1022D)
    thanks
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    thanks
    Need to use a combination of series and parallel wiring to present a 2ohm load to the amp. also check that amp should be 600wrms or higher and 2ohm stable
    Heres a pic to make life easier.
    vz ss ute
    Feb 2009
    alright iv connected the amp up the the sub boxes.... now the wire from the sub box to the sub...
    have i connected them correctly?
    Fonzie's Avatar
    300zx 2+2 Targa
    Aug 2008
    The sub box should only have two terminals... or if it has more, you only need two. Connect the monoblock to them, then the subs in this config. Assuming your amp can take them at 2ohm.
    vz ss ute
    Feb 2009
    cheers guys but im a total NOOB! like the biggest noob about car audio possible.
    so im going to join the negative wire to both negative terminals and the same for the positive?
    Fonzie's Avatar
    300zx 2+2 Targa
    Aug 2008
    Yes, and then you have to bridge (connect) the other two empty terminals on each sub.. Keep asking questions if you have trouble. It's better to query than blow up expensive equipment
    vz ss ute
    Feb 2009
    i feel like the biggest noob now! what do i use to bridge the empty terminals?
    Fonzie's Avatar
    300zx 2+2 Targa
    Aug 2008
    Relax mate, we all had to start somewhere. Just use some extra speaker wire.
    vz ss ute
    Feb 2009
    awesome!!! i totally get it now. if you were any closer id buy u a pint! cheers man ill let ya know how they go
    Fonzie's Avatar
    300zx 2+2 Targa
    Aug 2008
    Haha I'll hold you to that if i ever move to perth.
    Just to elaborate on some of the math for you; Wiring things in parallel (All positives together, all negatives together) halves the load. Wiring things in series (Negative attached to the following positive, repeat) multiplies the load by the number of drivers (Assuming they're all rated the same). Using the particular compilation of series and parallel wiring that you're doing doubles the load, then halves it, leaving us with the number we started with (2 ohms).
    Good luck.
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    I don't know if anyone has noticed but in th OP they say "the wire on the right is positive hand the wire on the eft is negative... what to do?". Well see how the right connector has a black ring on it, that means it should be a negative. This won't hurt your sub but it will run in opposite phase.
    Ronald Reagan (1986)
  15. #15
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Quote Originally Posted by acarmody View Post
    I assume he meant for the unwired voice coil in that pic (assuming thats how the terminal posts are configured)
  16. #16
    djs7cc is offline Dylan
    VZ Executive Ex Cop
    Aug 2009
    it depends on the ohms on the amp
    u wanna get it checked out to make sure ur not doing anything incorrectly
    have a drive down to JB hifi and they can make sure ur doing it right for about 20-30 bucks
    have a look at what he says and does and it will help u for future
    if u've already done it well done
  1. 2 outputs (head deck) 4 inputs(amp)
    By mad_dog in forum Car Audio
    Last Post: 05-06-2009, 12:04 PM
  2. Inputs on Subwoofers
    By Deutscher in forum Car Audio
    Last Post: 21-04-2009, 12:06 AM
  3. Crossover inputs/outputs...
    By neel in forum Car Audio
    Last Post: 18-02-2008, 04:38 PM
  4. 4 Channel anp install, speaker level inputs
    By AshK in forum Car Audio
    Last Post: 26-09-2007, 11:43 AM
  5. VT computer inputs diagram? got one?
    By petespipes in forum Electrical Wiring / Questions
    Last Post: 15-07-2006, 03:21 PM
