hi guys,
Just got my Vx converted to a manual and unfortunatly i was using the clutch cable grrommet for my amp wires. Now i just need to know where to run the amp power leads through the firewall....any ideas?
There is a rubber grommet on the passenger side of the firewall, with plenty of access. If I remember correctly it was quite easy to get the power cable through there without having to have to remove anything. You just need to make a new hole and push the cable through. It's also quite easily accessible from the interior, just pull the carpet down just below the glovebox and it should be directly behind it. Otherwise I'm not sure with VX models, but there is also a grommet on the Driver's side however may be less accessible because of the brake master cylinder.
