Results 1 to 3 of 3
Thread: VZ Head unit change
    djs7cc is offline Dylan
    VZ Executive Ex Cop
    Aug 2009
    Default VZ Head unit change
    Hey guys
    im busy changing my stock head unit for a double din alpine dvd player
    removed the head unit and cage
    not too sure where to go from here
    i will do all the wires but if theres anything i need to know or do please let me know
    thanks guys
    VK
    Jul 2004
    You'll need some sort of an aftermarket wiring harness to plug into the vz harness. As you can probably see the vz one is very short and hard to work with. Cutting into it would be a very messy exercise also.
    When installing my h/u I actually ripped off the socket piece on a broken vz unit i had lying around and soldered to that. Also you'll need to modify the aerial connector as its not a standard one. Once again I soldered to the socket i ripped off an old vz unit.
    Also, a CAT10 or something similar is required if you want to retain use of the steering wheel controls.
    Run the RCAs down the passenger side as there is a decent gap behind the head unit on that side to run them through.
    VZ Executive Ex Cop
    Aug 2009
    thanks man
    i pretty much knew all that
    haha
    i didnt know that the wires are so short
    what i did was i cut the wires near the loom (im gonna keep it for one day maybe i sell the car) and just wired them like that
    i gotta get a euro plug adaptor for the airial tomorrow from work (JB) and a cat10
    i can get used to it without having a cat10 but im always pushing the buttons and nothing works
    haha
    ill post some pictures up if ur interested???
  1. Replacing VT head unit with BT ipod unit
    By nickbedford in forum Car Audio
    Last Post: 23-06-2009, 03:00 PM
  2. Head unit pre-out to sub?
    By SKNOT9 in forum Car Audio
    Last Post: 09-05-2007, 10:22 AM
  3. VE Head unit in a VZ??
    By scottishgit in forum Car Audio
    Last Post: 19-10-2006, 01:19 PM
  4. Head Unit Change
    By raZel in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-10-2005, 07:29 AM
  5. VR Head unit
    By Nikkojoe in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2005, 10:44 PM
