Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: Amp + sub help!!!
    98 VT Supercharged
    Apr 2009
    Canberra, Australia
    Default Amp + sub help!!! PICS ADDED
    I've recently bought 2 10inch Rampage subs and a Clarion APX1301 monoblock AMP, Now... The amp was installed all good, power cable, earthing, Remote turn on and RCA cables ETC...
    HOWEVER i got ye old speaker cable out hooked up 2 subs like you should, rechecked everything but the EFFING subs are not working.
    I DO know that the subs are not blown as before installation they were used with the surround sound in my room.
    So is there any way the speaker cable or bloody anything would be holding them back from working, I can supply pics of the setup if anyone would like them to help me out.
    I also thought there might be some gay problem with the RCA OUTPUT from the back of the headdeck as insted of the plain ol rca output it has 'Rear out, Front out' and Sub W out' but im just thinking out loud here.
    any help would be greatly appreciated
    CHEERS!!!!
    2002 VX II Acclaim
    Aug 2008
    Yer show us some pics, and we will see if anything stands out.
    And am i right in assuming youve got the monoblock hooked up to Sub W Out?
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    If you have the RCAs hooked up to the "sub out" on the headunit (like you should) then theres a good chance you will have to turn on the sub channel on the headunit. At least thats the way it is on my Pioneer unit.
    What headunit are you running?
    Does the power light on the amp turn on?
    98 VT Supercharged
    Apr 2009
    Canberra, Australia
    Quote Originally Posted by Philthy View Post
    Yeah RCA is plugged into SubW out and the Sub is turned on through the head unit, and yeah the amp light is on, i tested every lead on the amp individually to see what it could be, no light without ground.. obviously, no light without remote turn on or power lead, so there all in, the lights on, so its something to do with the in and out of the audio
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Quote Originally Posted by dirtjumper005 View Post
    hey mate, could anything be touching each other to make it short? Usually shorting makes the subs cut out on and off, however it might be worth a check
    VZ Executive
    Nov 2008
    check your crossovers on the amp, might have the high pass on instead of the low pass
    98 VT Supercharged
    Apr 2009
    Canberra, Australia
    Ive checked and re-checked the X-over, and as to anywires touching, when i was installing it all i double checked all the wirings when i finshed for anything like that, so im stumped, ill hook up photos of the entire set up 2moro for a bit more of an insider
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Check to make sure the speaker wiring is properly connected to the subs (sometimes they can come undone inside the box).
    I would try connecting the RCAs to either the front or rear outputs on the head-unit, may be also worthwhile to try another set of RCAs?
    150db in a commodore =
    Philthy's Avatar
    Aug 2005
    I was going to suggest the wires in the sub box as well.
    Then it wouldn't hurt to try hooking up any old speaker you have lying around and seeing if that works
    98 VT Supercharged
    Apr 2009
    Canberra, Australia
    I tried with an old speaker... NADA, still no doof doof, here is the pics of the entire set-up to help you all out to help me out.. and if anyone asks, its grounded under the back seats
    chrism182's Avatar
    chrism182 is offline VX S Pack
    VX S Pack M5
    Sep 2008
    Victoria, Australia
    Dunno if it's an issue, but I haven't got my sub connected with that sort of speaker wire. Mine's connected with a big blue cable.
    Hope that helps,
    Chris.
    eziautoparts.com.au
    Your total auto parts store on the web!
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Mate that wiring for the subwoofers, at the amp youve got the two negative wires (the ones with the black stripe) going to the far side (in the 5th pic) + and - of the amp. The two positive wires are going to the + and - of the nearest terminal in that pic.
    Then at the box terminals it looks like youve got each pair of speaker cable going to each sub?
    If im right this means youve got one sub hooked up to both of the negative outputs of the amp and the other sub hooked up to both the positive outputs of the amp?
    98 VT Supercharged
    Apr 2009
    Canberra, Australia
    Quote Originally Posted by holdenboy View Post
    yeah I know that man, first thing i questioned when i sore the set-up diagram in the amp booklet, one of the first things i did was change the wiring so its the normal + to + and - to- between the amp and sub
    Philthy's Avatar
    Aug 2005
    Are the fuses on the amp still good? It might be the photos playing funny buggers but at least one looks blown
    I have always used bigger speaker wire for subs as well but it should still work I guess.
    EDIT: Ahh, I missed that one Holdenboy. Too busy moving my car out of the hail
  15. #15
    98 VT Supercharged
    Apr 2009
    Canberra, Australia
    I'd hope there intact, what would be the odds of a brand spankin new amp coming with EFFED fuses, however if the fuses were gone, wouldnt the amp just not work?¿
    if so i guess ill try new fuses, if still nothing, i shall get myself to audiotech and send a questionmark there way
  16. #16
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    The amp is turning on so its not a power/ rem / earth / fuse problem.
    The xover and gain settings.....theyre on minimum right? Try turning them up to around 1/2 on both.
    The only other ting i could suggest is trying another set of RCA cables...
  17. #17
    Philthy's Avatar
    Aug 2005
    I thought gain, xo and bass boost were all flat out looking at that picture, but even then try turning them down to half and boost off because that will be too high.
    As Holdenboy said before as well, the speaker wire should be + to + and - to - on both channels. Even try just getting one of them to work maybe
  18. #18
    Philthy's Avatar
    Aug 2005
    Looks like there might be a few strands of speaker wire crossing over there as well. Make sure nothing can touch anything it shouldnt
  19. #19
    98 VT Supercharged
    Apr 2009
    Canberra, Australia
    Its deffinently not the RCA cables, as i had the ones with the amp kit, which i didnt use as i bought a set of rampage competition cables, however i did try the rca cables included with the amp kit
  20. #20
    98 VT Supercharged
    Apr 2009
    Canberra, Australia
    Nah that wasnt the problem as i just hooked the wires back up so they were in place just for the time being, when i was doing the wiring i was being carefull with all that jazz
  21. #21
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
  22. #22
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    if u plug the rcas to the rear out instead of sub out, of the headunit to try it.. does it work?
    if not, try using the hi inputs to see if that works..
  23. #23
    98 VT Supercharged
    Apr 2009
    Canberra, Australia
    Quote Originally Posted by ephect View Post
    Yeah I tried the RCA outputs for the rear and front, still nothing, and as to the hi-input, what do you wire them up to?
  24. #24
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    u use the speaker wire from the head unit and it plugs into the hi plug on the amp. coz the speaker wires have a higher voltage than rca's.
    so headunit speaker outs -> to amp hi input.
    narrow it down to 1 sub plugged in, u can also try 1 speaker (not sub) wired to the amp to see if it works too, rules out the subs
  25. #25
    98 VT Supercharged
    Apr 2009
    Canberra, Australia
    YABBA DABBA DOO, All working now, got around the checking out the entire system, and there was a fault in the speaker wiring, the sheath of both positive and negative wires were split where the wires are stuck together, so got more wire of the 100m reel I have, SAME ****ING THING, the wires were shittely made, took the C*&T back, got new wires, WOOT, all working. Thanks for all your guys help
Tags for this Thread
