Results 1 to 5 of 5
Thread: What will happen if i try draw 75amps of current from 8awg?
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Question What will happen if i try draw 75amps of current from 8awg?
    Hey,
    i know that 8awg only carries about 50amps of current, however i want to see how my system goes with both amps running, totally 75amps of current. i am buying 4awg power wire kit next pay, so its not a long term thing i just wanted to see how it sounds. Will i screw anything straight away or would it be okay for five minutes? Or a week? What will happen?
    Cheers.
    vr series2 berlina
    Aug 2009
    McCrae
    i depends on how much the amps actually draw what there fused at is the mak they will drab about 3/4 of that but if u get a decent low and draw oyer the 50A u wil just blow ure fuse on the power cable hope that helps
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    The amps will rarely draw anywhere near maximum current and when they do it will only be for milliseconds. It'll be fine for just music until you get the 4ga.
    Dec 2008
    thats awesome thanks very much guys, though the fuse on the power cable is only 60amps. i'll hook it up now and have a listen.
    Cheers.
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    should not be too much of a drama for a short period of time mate. You may suffer a noticeable voltage loss as higher outputs on lower Hz and the cab;e may get warm. Short period of time? Yeah, I'd do it. Actually I wouldn't but you could!
  1. V8 starter motor: current draw
    By Morton in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-05-2009, 06:30 PM
  2. 4, 6, 8AWG power cable
    By Shaneus in forum Swap / Wanted to Buy / Trade
    Last Post: 21-03-2007, 08:08 PM
  3. CAI - best place to draw air from
    By Sphinx in forum General
    Last Post: 11-01-2006, 09:53 AM
  4. Does the air-con always draw the same amount of power when it's on???
    By vq~gangsta in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-12-2005, 08:37 PM
