Results 1 to 6 of 6
Thread: antenna issue
    VY
    Aug 2009
    Default antenna issue
    Hi People,
    this is my first post as i just found this web page.
    I have just installed a new system in my car all running fine only thing that annoys me is when i start the car up the antenna comes up even when i have it in usb and cd mode is there any way to make the antenna stay down while it is in usb mode and cd mode and only come up when the radio is turned on?
    i am running a pioneer deh-6150bt head unit if this helps.
    If any one could help it would be a big help thanks.
    227shanno's Avatar
    227shanno is offline Donating Member
    vy ss 5.7
    Aug 2009
    wollongong
    the antenna is ment to come up. no matter what your doing eg radio,cds,mp3... as soon as it gets power, up it goes
    VYII Equipe S/wagon V6
    May 2009
    Melb, Vic
    Monitor the ANT trigger on the radio switching between modes to see if it's on all time or switch's on and off ... as you may be able to find way to retro fit a control relay as the standard ant is controlled via the BCM.
    Cheers,
    Dave
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    It's possible to do the above, buts its much easier to install a small toggle switch inline with the antenna control wire so you can put the antenna down when not listening to the radio.
    150db in a commodore =
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    I had the same problem when I had my Pioneer H/U, but when I upgraded to my expensive Kenwood unit it only went up for radio and down for everything else. I think it just depends on wheather you H/U has that feature or not.
    Ronald Reagan (1986)
    May 2009
    Melb, Vic
    It's nothing to technical holdenboy.. A simply solution found here. Although I haven't tested it, I can't see why it wouldn't work
    Agreed if you have the ant powering up via a radio that simply powers on through any play mode a simple switch would solve the problem.. Hence I suggested to see if the HU actually does the triggering
    Cheers,
    Dave
  1. Antenna issue.
    By And_ROOS in forum Car Audio
    Last Post: 10-03-2009, 06:43 AM
  2. VY Antenna
    By Loupy31 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-01-2009, 05:44 PM
  3. VX Series 2 Executive - Start Issue + Boot Button Issue!
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 02:28 PM
  4. VS Antenna!!
    By danny6424 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2005, 04:22 PM
  5. VL Antenna
    By Aussie_Watto in forum Car Audio
    Last Post: 05-07-2005, 05:39 AM
Tags for this Thread
