Results 1 to 13 of 13
Thread: Amp and sub questions
    vt berlina
    Jun 2009
    wa
    Question Amp and sub questions
    I got this fusion amp for $80 new and was wondering how much power i really get out of it? It says 76w rms but i have heard that these figures are usually unreliable.
    FUSION Electronics ? Car and Marine Audio
    I am looking to bridge 2 channels and power a sub, probably the fusion encounter 12" which i can get for $50. Has anyone heard one? Are there any subs $50-$100 that stand out?
    VR II Executive Manual
    Apr 2009
    Rating products at 1% THD is a bit slack to start with, and that's assuming their numbers are accurate. Their bridged into 4 ohms figure is a little less than 2x their 2 ohm figure, so that's a good sign. The fact that their 2 ohm figure is way less than 2x their 4 ohm figure is less encouraging. I reckon it'd be safe to assume that you could get 150W RMS from a bridged channel into a 4 ohm load without breaking anything, but that's based on intuition, not experience with the actual product.
    As to the sub - what sort of enclosure were you looking at? Sealed, ported, bandpass, IB? In any case, it's better to choose your driver to suit the application.
    95 vs calais V6 Auto
    Aug 2009
    Dora Creek
    As far as i know all car audio places bullshit about there power but basically i think you get about a third of the max wattage, i used to have a boss 400w max 2 channel amp powering 2 12in boss subs in my vl and it used to go pretty good, alot of vibration in the old girl, the rear view mirror would shake to the point i couldn't see out of it and my mates would hear me coming from down the road, i was happy with it. so it should go alright i think.
    vt berlina
    Jun 2009
    wa
    Sorry im new to car audio what does bandpass and IB mean? I am probably going to port the box but am not sure yet. Is it better to get a larger sub or get one that matches the amp closely in power?
    Aug 2009
    Dora Creek
    A bloke told me once that to run a 1000w sub your best off to run a 1000w amp, i got no idea what bandpass or IB mean. i was just happy with the setup i had and didnt think i needed anymore.
    | evaN |'s Avatar
    | evaN | is offline mmm bass
    VT
    May 2006
    SE Melbourne
    really for 100bux you cant get much that really stands out.
    If you can get the fusion sub for 50bux then why not. It's rated at 150watts rms which will be ok for this amp.
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Bandpass is basically a sealed box with the sub firing into a ported enclosure, definately not something to try if you dont know what youre doing.
    IB means Infinite Baffle, basically no box at all....like mounting subwoofers in the parcel shelf.
    If you do go with a ported enclosure, make sure you get the internal volume and port size / depth right, otherwise it can sound like crap.
    As far as the sub goes, its up to you....pretty much no matter what sub you get your only going to be pushing 150wrms into it, so maybe something with a high sensitivity rating would be ideal?
    150db in a commodore =
    vt berlina
    Jun 2009
    wa
    Which is better for rock? Sealed or ported? I was told by a friend to port so i would get more out of it.
    Also where can i get a sub box? Should i get a cheap one or spend a bit in case i upgrade my sub later?
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    A sealed box should give tighter, cleaner bass and will be the smallest one if boot space is an issue.
    A ported box will be louder, but will be a bit "boomier", and needs to be a bit bigger.
    You can make your own box in a couple hours to the exact specs of your sub to get it sounding best, or you can buy basic generic overpriced boxes from most car audio places
    Apr 2009
    Sorry, I forget sometimes that the jargon doesn't come naturally.
    I'd personally suggest a sealed box, they're much more forgiving, you can muck them +/- 30% and they'll usually still be fine (a fact those cheap boxes rely on - very few subs are perfectly suited to 1.5 cubic feet, but a great many will work well enough). Most guys seem to run ported these days, but they're much harder to build and tune correctly for the driver, so they tend to sound boomy and "slow".
    If you're up for learning the jargon, look up WinISD, it's a speaker box sim tool - it's excellent, provided that the parameters you feed it are accurate.
    vt berlina
    Jun 2009
    wa
    I have the fusion sub ($44) and don't really have the time to spend or the ability to spend making a sub box so i will just buy one online. Thanks all
    Philthy's Avatar
    Aug 2005
    In that case have a look at the sub's spec sheet, find it's ideal box volume for both sealed and ported (and port info), and find the closest match you can. With cheap gear you will need everything you can get to make it sound good
    vt berlina
    Jun 2009
    wa
    Yeah its 1.009 ft^3 sealed and their are plenty that size around. I had a listen in the store and its loud enough for me at the moment.
  1. Many different questions about V6 S1 VN
    By crazybiker in forum V6 Development And Modification
    Last Post: 22-11-2008, 09:22 AM
  2. SSZ questions
    By BANKS in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-04-2008, 03:09 PM
  3. Few questions
    By Ryan Mckd in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-04-2008, 01:47 PM
  4. VC Questions.
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-03-2006, 07:03 AM
  5. VZ SV8 questions
    By BLACKVZSV8 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 21-02-2006, 08:52 PM
