Results 1 to 7 of 7
Thread: best way to install speakers in vk door
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    Exclamation best way to install speakers in vk door
    hey..
    an upgrading my stereo system and am wondering how hard is it to install some speakers in the door. currently there are 2 speakers on the rear parcel shelf.
    thanks
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    Fonzie's Avatar
    Fonzie is offline Just lost the game.
    300zx 2+2 Targa
    Aug 2008
    Gippsland, Victoria.
    Depending on what look you want... Rip off the door card, and see if there's enough room mount it flush to the door. If there's not, either space it out with MDF ring(s) or get/make a pod.
    For it to look relatively original, your best bet would be making some sort of pod... Colour and material matching, and try to match the lines of the original trim. Fiberglass maybe?
    If you just want speakers, and are happy to do it on the dodge, just space it out with MDF rings and use the cover that comes with the speakers
    Quote Originally Posted by Philthy View Post
    ....man, I love how white your car is
    commodore
    Aug 2009
    australia
    or you could get yourself some vs commodore speaker pod map pocket assemblys and use them i recon they look good and space them out too
    Luke0011 is offline Car Audio Installer
    VZ Berlina 2005
    Jan 2007
    The old 15cm by 15 cm trick. Looking at the bottom left of your say drivers door with a black marker go up 15cm from the left and across 15cm. mark with a dot. Centre point for your 6.5 inch. Clears the double metal at the botttom left of your door skin and allows clearence for the window winder.
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    yup...what luke said! Works a treat!
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    thanks.....
  1. Speakers install
    By Matt_27 in forum Car Audio
    Last Post: 05-07-2009, 10:46 PM
  2. How To: Install speakers
    By U2Bono in forum Car Audio
    Last Post: 22-06-2009, 07:08 PM
  3. Replies: 2
    Last Post: 04-09-2008, 08:18 PM
  4. removing the trim to install speakers
    By clyde in forum Car Audio
    Last Post: 02-10-2007, 07:31 PM
  5. install speakers and amp - vu ute
    By muzwoldian ss in forum Car Audio
    Last Post: 12-06-2006, 07:38 PM
Tags for this Thread
