Results 1 to 13 of 13
Thread: trigger wire for more than one amp
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Default trigger wire for more than one amp
    Firstly, sorry if it has been covered before, but i did search, and i didn't come up with anything.
    I currently have 3 amps, and i have just spliced the trigger wire and connectted 3 wires to it,twisted it, and taped it. It's been working fine, but something is telling me there's a better way to do it. I've pulled my whole install out at the moment, so i can neaten up all the wiring ect, so is there another way to go about with the trigger cable? like a junction box or something?
    Also, i want to buy a distribution block, as i currently have 3 power cables, running from the battery to the amps, as i hooked them all up using seperate wiring kits. Is there any difference between brands, cheap one's, good ones? Is there anything i should look for when buying one?
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Instead of twisting them solder them properly, much much better.
    The Stinger range of distribution block are really cheap anyway, just get them. I got a 0-gauge in to 4x4-gauge out for about $25.
    Ronald Reagan (1986)
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    I've answered this a couple times the last few weeks but I'm pretty sure none have been in a dedicated thread about it.
    On mine I run 1 long wire from the headunit into the 1st amp, then short runs from there to the next amp and the same again into the 3rd amp. This way there is only really 1 remote wire running across the boot, it just goes to each amp along the way. That is the neatest way I could think of doing it at the time
    VY Berlina V6 / R31 Skyline
    Dec 2008
    ^^+1 i have done the same with my trigger wire to two amps, and will be doing it to three. it looks really neat if you cut the cable the right length.
    also with distro blocks, the aepro ones are fairly cheap, i have a rampage on that wasnt very cheap but seems really good.
    Mar 2009
    Cairns White Rock
    Quote Originally Posted by Philthy View Post
    Yeah sorry to bring it back up again, but i couldn't find anything.I even looked atall the boot install pictures, trying to come up with ideas. Are there simialar things available such as a distribution block, for the earth leads, and trigger leads? that's what i had in mind, one wire for each, then branching off to each amp from there. I will be adding a 4th amp shortly for the second sub, so i really want to have the least amount of wiring i can, i keep it looking tidy. I've seen some pictures of setup, where they have quite a few amps, and you can't hardly even see any of the wiring. My boot looks as though someone grabbed 30 metres of cable, wound it up, tied a few knots in it,then just threw it in there lol
    VZS-Ute06
    Aug 2006
    Western Vic
    Cool
    I use the active lead from the cig lighter in the console as the trigger wire
    also added a illuminated kill switch into the console
    VZ-Rob
    98 Ron Powerchip: CAI: SuperLows: GTS Swaybars: Tinted: SS Grille: SS Vents: SS 2:25 Twin Exhaust: ASR Audio:
    Philthy's Avatar
    Aug 2005
    Quote Originally Posted by HoldenCommodoreVP View Post
    I'm pretty sure I've seen little distro block thingo's at Jaycar that would work for splitting remote wires . I don't see why that wouldn't work
    BrAdAsS is offline Banned
    VX Executive A4
    Dec 2005
    Brisbane Northside
    The headunit should say what it's trigger output puts out as to how many devices you can safely attach.
    Using a relay, connect the headunit trigger wire to pin 85, pin 86 to chassis ground.
    Run a wire from batt+ to relay pin 87
    Run a single wire from relay pin 30, like you have to each amp already.
    that way as long as you don't exceed the relay rating everything will be sweet.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    So it would be a bad idea to run the trigger wire from the amp's power supply cable? Would this cause noise? We are currently getting a lot of engine noise through the speakers.
    We did a quick hook up of an amp to the existing wiring that was already in the car. We have a four channel running fronts and rears but no subs at the moment. The trigger wire was already spliced to the power supply cable, we just plugged everything in.
    Another quick question, sorry to steal the thread, which way do the speaker wires actually go in relation to the colour of them? The insulation is the pinky clear type with no way of telling which wire is + and which is -. The only difference is colour of the wire itself, one is copper one is a silver colour. Without actually pulling the door trims off and checking the front speakers, is there a standard way to hook them up?
    Visit my Facebook page
    Philthy's Avatar
    Aug 2005
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Wouldn't running the remote wire from the power wire cause the amp to be on all the time since it is connected directly to the battery? I would be surprised if you didn't have battery drain issues with a setup like that.
    As far as the speaker wire goes, it would depend on the guy who installed them, but with wire like that I have always used the copper one as +ve, purely because it is the redder of the 2.
    If you can see the speaker cone you could use the old 9v battery trick to figure it out, but thats no good if they are hidden behind grills
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Don't have any battery drain issues at all. Might have to run one to a switched wire.
    With the speaker wires, I couldn't hear any difference which ever way they were connected so it looks like I will have to pull a door trim off.
    VZS-Ute06
    Aug 2006
    Western Vic
    Cool
    So it would be a bad idea to run the trigger wire from the amp's power supply cable? Would this cause noise? .........
    Damn Right !
    Try this
    Quick easy clean
    Running 2 Amps of Stock Bluapunkt
    VZ-Rob
    sycvs is offline commo for life
    vs executive
    Jul 2009
    phillip island
    i had two amps running and had the wire splited and then 1 to each never had a cut out but when i ran it from 1 to the other it always would cut out in my first car it ran from the amp power / bat and was always on and never had drain isues as long as i started it at least every 24 hours
  1. what color for trigger wire
    By kerrylee_90 in forum Car Audio
    Last Post: 30-08-2009, 07:58 PM
  2. Trigger Lead??
    By VR_Berly in forum Car Audio
    Last Post: 30-12-2008, 09:01 PM
  3. Help with Write-Off Trigger!
    By Fekason in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-06-2006, 11:09 PM
  4. Amp Trigger ?
    By Fletch_QLD in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-08-2005, 08:33 PM
  5. Amp Trigger
    By Dee Bee in forum Car Audio
    Last Post: 31-05-2005, 01:08 PM
