Results 1 to 3 of 3
Thread: amps cinundrum!
    VRoooom!'s Avatar
    VRoooom! is offline Vroooom!
    VR Executive Series One
    Aug 2009
    Default amps cinundrum!
    need a new amp in my vr commo.
    i was gonna buy a 1200W Fusion Powerplant 4 Channel Amplifier.
    but my old amp only has screw cables which the fusion one doesnt have.
    i also came across a FUSION 600 WATT 4 CH AMPLIFIER which is compatible with screw cables, but its only 76 WATTS RMS PER CHANNEL @ 4 OHMS.
    problem is its weak as, ive been told
    what can i do from here?
    is it worth getting a 1200w with cables fitted in?
    thanks guys
    Vroooom!
    VZ Executive
    Nov 2008
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    I think he's referring to the normal screw terminals that requires the cable to have a "U" (fork) or ring terminal fitted to it, as opposed to the insert type terminals with an allen key / phillips head screw which clamps down on the cable.
    Its no real issue though, you will just need to cut off the terminals, strip back about 20mm of insulation, insert into the hole and tighten up the screw. If its the other way round you just need to buy some ring / fork terminals to crimp / solder onto the cables.
    150db in a commodore =
  1. 2 Amps.. How?
    By tr3nt in forum Car Audio
    Last Post: 16-06-2006, 10:29 AM
  2. 2 Amps
    By VRSS in forum Car Audio
    Last Post: 25-02-2006, 08:22 PM
  3. Amps
    By G4orce in forum Car Audio
    Last Post: 11-11-2005, 10:40 PM
  4. Amps
    By ducatis in forum Car Audio
    Last Post: 27-07-2005, 03:15 PM
  5. Amps
    By VNCommo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-04-2005, 06:48 PM
