Results 1 to 8 of 8
Thread: newbie car audio question!
    Vt S Pack Series 2
    Nov 2008
    Default newbie car audio question!
    okay as the title suggets i have a newbie car audio question......(please dont flame )
    i have 2 kicker comp vr (12 inch) subwoofers lying around, i read somewere that they came in dual 2ohm or dual 4 ohm models?....how do i find out which one's i have?
    i also have the kicker zx750.1 mono block amplifier so if anyone can shed some light on how to wire the subs together that would be awesome!
    many thanks!
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    I imagine it would have the voice coil info on the sticker on the magnet, but failing that you can measure the resistance with a multimeter.
    Luke0011 is offline Car Audio Installer
    VZ Berlina 2005
    Jan 2007
    Yeah well normally, they are written on the woofer but measuring the impedance ( resistance ) is required. The reading wii be approximatly around 2 or 4 ohms. Hopefully you have the dual 2 ohm model as that will allow you to wire it the the amp as a 2 ohm load by connecting the woofer coils in series and then connecting the 2 subs in paralell. If you have the dual 4 ohm model you will connect it as a 4 ohm load. It just means the 2 ohm setup will get the most from your amp.
    CH Lancer
    Jul 2009
    Vt S Pack Series 2
    Nov 2008
    nah i havnt had a chance yet, i have the day off tomorrow so ill post it up in the morning!
    Vt S Pack Series 2
    Nov 2008
    okay sorry for the delay, they are 2ohms per sub. (comp vr)
    any one no how to wire them up to my monobloc which is the kicker zx 750.1? im pretty handy with wiring and what not is someone could throw up a diagram of some sort?
    thanks!
    Vt S Pack Series 2
    Nov 2008
    VR II Executive Manual
    Apr 2009
    OK.....I think you've described having a dual 2 ohm coils on each sub, yeah? Assuming your amp is stable for driving a 2 ohm load, the best way to hook it up would be like:
    | Input +
    Sub 1
    Sub 2
    | Input -
    That is to say, wire the voice coils of the each sub in parallel (+ to +, - to -) giving the equivalent of a 1 ohm sub (Because 1/Z(parallel) = 1/2 + 1/2 = 1, therefore Z(parallel) = 1/1 = 1 ohm).
    Then wire the two subs in series (+ to -), giving a 2 ohm load for the amplifier. (Because Z(series) = 1 + 1 = 2 ohms)
    But FIRST, check whether you're amplifier is rated to drive 2 ohm loads. I can't be bothered to find the product page myself.
  1. newbie question
    By matty11 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-09-2009, 09:04 PM
  2. Newbie Question!
    By WOODY'SVRSS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-06-2009, 07:42 PM
  3. newbie question
    By vp5lute in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-09-2008, 11:02 PM
  4. Newbie Question
    By TexasRealtor in forum The Pub
    Last Post: 16-01-2007, 04:48 PM
  5. Newbie! Just a question
    By ?uestlove in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-07-2006, 05:41 PM
