a panel made from at least 9 mm mdf ( prefer 12mm ) on either side and trimmed in carpet will do the job, its a little tricky to make and look like it was factory fitted but easy enough to make a basic panel to firmly mount your amp.
Hey guys i had gas put in last week and now i am getting my sub and amp put back in tomorrow but i have a question on where to mount the amp.
The amp used to be mounted on the back of the rear seats but now i have the tank in the back that is not an option.
I need to have the amp mounted in the boot somewhere and not on the back of the sub box. The reason is that i will need to take out the sub occasionally to use the boot space for a cricket bag which will only fit without the sub.
Any ideas Guys??? Thanks alot
Check out my ride: GILLO's VT Berlina - SS Kitted - VY Sigs - Leather Interior
As Luke0011 said... I have a template for both sides if your interested, I can trace it onto a piece of paper and send it off to you. Then all you have to do it trace it onto a piece of carboard and then trace it onto the MDF (or just trace it directly onto the MDF) and cut it out with a jigsaw. Easy done![]()
