Results 1 to 4 of 4
Thread: good idea or leave it?
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    Exclamation good idea or leave it?
    hi all, i have a 800w mono-block amp, and im running it off the same wiring that the headunit is running off instead of the battery terminal, due to shortage of cable and my stinginess lol, it was fine with 1 sub, but now ive hooked a 2nd, and it blew a fuse, would i benifit from hooking it up straght to battery? or shouls i put a bigger fuse?
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    So youre using small cable to power the amplifier?
    Did it blow a fuse at the amp or at the fusebox?
    DO NOT put a bigger fuse in EVER!!! You could cause a fire as the cable will burn up before the fuse blows.
    Youre amplifier and subs will benefit from upgrading to 8awg power cable and an appropriate sized fuse within 30cm of the battery terminal. The more power the amp can pull from the battery the more power the amp can produce, which means louder subs Also use the same size cable for the earth.
    Power in = Power out.
    150db in a commodore =
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    Your fuse blowing is a warning that something is trying to turn your car into a pile of ashes and molten metal. Do the job properly the 1st time and you won't have any future problems
    vn_v6's Avatar
    Aug 2009
    victoria
    i understand haha, im going to cable it properly, who doesnt want more bass?
  1. Good Idea? Bad Idea?
    By WogBoyz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-03-2009, 01:00 PM
  2. Good idea
    By lgnd3800 in forum Jokes/Humour
    Last Post: 04-02-2008, 03:25 PM
  3. Not a good idea
    By Pretender in forum The Pub
    Last Post: 03-05-2006, 03:56 AM
  4. Good Or Bad Idea?
    By bad_boyz in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-03-2004, 11:19 PM
