Results 1 to 12 of 12
Thread: Pioneer TSWX11A 150 watt amplified subwoofer - has anyone used it?
    EQUIPED is offline AM VZ
    VZ Equipe 2005
    Sep 2007
    Default Pioneer TSWX11A 150 watt amplified subwoofer - has anyone used it?
    Hi, interested in hearing from anyone who has used a Pioneer TSWX11A 150 watt amplified subwoofer or similar product. pioneer amplified subwoofers
    This can probably fit under the front passenger seat
    Boot space is extremely important to me so can't put anything there, so regular subs are out
    I am ONLY looking for a 10-15% increase in base as the upgraded door speakers in my car already provide very decent sound...just need marginally more punch!
    Attached Thumbnails Attached Thumbnails Pioneer TSWX11A 150 watt amplified subwoofer - has anyone used it?-pioneer-tswx11a.jpg
    LATEST NEWS: The difference between a pigeon and a London investment banker - The pigeon can still make a deposit on a BMW
    VZ Equipe 2005
    Sep 2007
    ..... BUMP....
    anyone?
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    I havent used this particular one but used others......in my opinion they arent too bad, considering youre only after a marginal increase in bass it is an option.
    Also depending on your speakers fitted you could look into an aftermarket amplifier to increase their bass output?
    150db in a commodore =
    VZ Equipe 2005
    Sep 2007
    Quote Originally Posted by holdenboy View Post
    Thanks mate. Currently, the door speakers don't like too much base (a.k.a. some songs on high volume 35+) as they distort, so hoping to put in this amp+subwoofer to take some of the load
    2002 VX II Acclaim
    Aug 2008
    Quote Originally Posted by EQUIPED View Post
    What Holdenboy is saying is if your running aftermarket speakers off your headunit, they wont be working to there full potential.
    A while back for my VN wagon i bought one of those $150 kits from JB HiFi (headunit and 6" speakers)
    Went home, installed it and was MUCH better than my stock setup, but anything semi loud and the speakers would jsut distort from the bass.
    Then i went out and got an MTX amplifier to amplify the front speakers, and you can pump them up so much louder and get so much more bass outta them.
    So what i would try is to get a 2 or 4 chan amp and amplify your speakers
    VZ Equipe 2005
    Sep 2007
    Quote Originally Posted by anarklov3r View Post
    hmmm...so they would distort running off the head unit at high volume but perform much better on mid-high volume with an amp?
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Basically any speaker, whether it be a coaxial, splits system ect, is going to distort when it recieves too much bass, because put plainly, they are not designed to reproduce low bass frequencies. The only way to lessen the load as you decribed it, on your front speakers, it to run them through a HPF(high pass filter) This will cut certain frequencies below a set point. be it, 60hz, 80hz, ect. Let the sub produce the low frequencies, being as that is what their designed for, and you may find then you might not even have to amplify your front speakers, on a HPF they will play much louder, with less distortion.
    VZ Equipe 2005
    Sep 2007
    cool...I already have the RCA input mod done by Phreddy...so will try the HPF now. thanks!
    Mar 2009
    Cairns White Rock
    Oh your using the standard head unit? Then it wont have a HPF option onfortunately.
    VZ Equipe 2005
    Sep 2007
    yeah am using the OEM blaupunkt 6 disc stacker Will probably try an amp and see how the speakers handle it.
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Yeah, if you get a half-decent amplifier to run your front speakers it will have a high pass filter built in, if its adjustable (some arent) then set it to around 70-80hz, if the speakers dont put out enough bass for you then adjust the HPF down abit, re-listen and adjust as necessary
    Its abit of a trade off with bass response and speakers in general......If you crank the bass up (or lower the HPF too far) you'll notice they dont play as loud, its just about coming to a compromise and getting the bass and volume output your happy with.
    VZ Equipe 2005
    Sep 2007
    understood mate...thats very clear! Thanks
  1. 2 ohm wiring for pioneer subwoofer
    By r_i_d_a_h in forum Car Audio
    Last Post: 12-02-2009, 07:19 PM
  2. Pioneer 460 Watt 5 way 6x9's WITH MDF SPACERS! TS-A6991S RRP $329!
    By 1991_Vn2nV in forum Parts And Other Items For Sale
    Last Post: 27-05-2008, 05:33 PM
  3. 8 Inch Pioneer Subwoofer
    By Dirbatua in forum Parts And Other Items For Sale
    Last Post: 14-02-2008, 03:33 PM
  4. FS:Pioneer TS-A1681S 16cm (6 Inch) 4-Way 260 Watt Speakers
    By ruredi in forum Parts And Other Items For Sale
    Last Post: 06-05-2006, 01:24 PM
