Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: can subs blow up?
    VZ Executive - Clubsport Conversion
    Jun 2009
    Castle Hill, Sydney
    Default can subs blow up?
    im currently running 2 12 inch rockford fosgate p2 subs in my vz powered by a 1800 watt boss audio amplifier. while i was listening the other day, the subs just stopped working. the amplifier and everything is still on but there is no sound coming through the subs. WHAT THE HELL?
    what are the options on what has happened.
    CH Lancer
    Jul 2009
    Boss Audio? You didn't buy it from Strathfield did you...?
    It could be the amplifier. Or the amplifier could have clipped the subs to death and thus its the subs. There could be a loose wire. You need to use the process of elimination and test to find out what is it.
    You could always pull a sub out and try to smell it to see if the coil is burnt but if your not sure what you are doing I wouldn't recommend touching it too much.
    Joe Bellissimo
    Shopping Secure - Car Audio Specialists
    www.shoppingsecure.com.au
    MSN/Email: sales@shoppingsecure.com.au
    Jun 2009
    Castle Hill, Sydney
    haha yes i did get it from strathfield. ive got a spare p2 lying around in my garage, when i get home to night ill plug it in n see what happens. i just dont think its the subs cause i didnt hear the cones like break or that burnt smell come so its a bit of a tough one.
    cheers ill comment back what happens
    CH Lancer
    Jul 2009
    | evaN |'s Avatar
    | evaN | is offline mmm bass
    VT
    May 2006
    SE Melbourne
    if you've got a DMM, check the resistance of the subbies voice coils. zero resistance = blown sub
    acarmody is online now Donati..Whoa Green
    VX Berlina
    Apr 2007
    Strathfield + Boss = FAIL. LOL, seriously, if the amp has a protect mode on it, it could have just done that. Also check the fuses on the amp. Everything else I would check has already bee said by others.
    Strathfield aren't all bad. I got my first sub and mono amp from a Strathfield. A Pioneer TS-W307D2 and a Pioneer GM-6800M (I think thats right), and on a good special.
    Ronald Reagan (1986)
    Jun 2009
    Castle Hill, Sydney
    hey again, i tried to connect my sub to my other boss audio amp thats powering all the front n rear speakers and the sub started kicking, so its the specific amp that was running the sub thats given up. im gonna give it back to strathfield n see if they can do something about it, the manager at the castle hill one is one of my mates so should be alright. as for the amps, im gonna get a dedicated rockford fosgate to run the sub, and a cadence to run my cadence speakers.
    cheers
    VX Berlina
    Apr 2007
    Yeah good idead in replacing the Boss amp. Also last time I checked the Rockford amps were still a bit pricey, try having a look at the new Cadence range for a new mono amp. Quite cheap and apparently bloody good.
    VL Shaggin Waggin
    Jul 2009
    Quote Originally Posted by | evaN | View Post
    you mean infinity, not zero..
    dynoryder is offline Banned
    vp executive wagon
    Oct 2009
    A.C.T.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Quote Originally Posted by BaggedVL View Post
    It can be both... Open circuit or short circuit, it depends what happens to the coil when it burns.
    CH Lancer
    Jul 2009
    Why don't we experiement on this? Who has some subs that they no longer want? I will happiliy run a couple thousand rms through them and upload it to youtube
    Joe Bellissimo
    VL Shaggin Waggin
    Jul 2009
    Quote Originally Posted by StoneX View Post
    very little chance of a subwoofer, ever, under any circumstances failing as a short circuit.
    thats a whole lot of turns in a coil to short out into a single blob
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    I see them nearly every day with resistances of 0.1ohm (short circuit) for a 4 ohm subwoofer with a burnt coil.
  15. #15
    VL Shaggin Waggin
    Jul 2009
    I doubt that.
    you can make whatever claims you want though
  16. #16
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Keep doubting, but that's a burnt 4 ohm coil measuring pretty much short circuit. Far from open circuit.
  17. #17
    '97 VS Commodore + '98 E36
    Apr 2005
  18. #18
    VL Shaggin Waggin
    Jul 2009
    thats no where near a short circuit, 0.1 ohms is a short circuit, hell, 0.7 ohms and chances are the amplifier would still run it!
    like I said:
    "very little chance of a subwoofer, ever, under any circumstances failing as a short circuit."
    a few shorted turns isn't a short circuit.
  19. #19
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    That one was 0.1 ohm, before taking the cone and voice coil out of the basket, due to the burnt coil touching the metal in the VC gap. So a speaker with a burnt coil will show up as a short in some circumstances.
  20. #20
    VY s m5 supercharged
    Aug 2008
    Quote Originally Posted by Joe Bellissimo View Post
    What state are you in i have a sub that i might not need as it has a crack in it from the dum ass tyre shop down the road lets just call them j******sons
  21. #21
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    I have a Clarion pxw1252 sitting here with a welded voice coil.... I can lean against the coil and it ain't gonna move. coil resistance reads .3 ohms. now how much of that is also resistance from my DMM leads?
    Stone, is that one of the new Champion series?
  22. #22
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Nah, it was just a TS-W307D4.
    [edit]
    Which do say "Champion series" on the cone.
  23. #23
    Tasmaniak's Avatar
    car
    Apr 2005
    underpowered? I sent one to you guys recently (ok about 3 months ago) because the customer insisted that the sub was at fault and he demanded that you guys replace it under warranty. What else could I do but sigh and just send it off? I got the answer I was expecting. Overdriven. Not covered by warranty.
  24. #24
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Yeah, I don't get how people think the sub can be at fault for burning. If it just stops working, then I understand they want it checked but when the cone won't move and it stinks like smoke, I just don't understand
  25. #25
    CH Lancer
    Jul 2009
    I wonder if it would be possible to install a fuse into subwoofers that would cut out once the subwoofer was receiving frequencies and current that would exceed its mechanical limits...
    Joe Bellissimo
  1. Help vn 5.0 blow by
    By calais_8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-06-2008, 11:24 PM
  2. FS: 2x 12" Pioneer VCCS Subs in Custom Box! Silver Cone Subs!
    By 1991_Vn2nV in forum Parts And Other Items For Sale
    Last Post: 06-01-2008, 08:27 PM
  3. vn motor blow up
    By BURK_POP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-01-2008, 01:02 PM
  4. How to blow 5k on a VN S1?
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2007, 11:07 PM
  5. will this blow my sub
    By lieos in forum Car Audio
    Last Post: 27-08-2006, 03:29 PM
