Results 1 to 9 of 9
Thread: circuit breaker vs fuse
    00' WH Stato LS1 A4
    Dec 2008
    Adelaide, SA
    Default circuit breaker vs fuse
    Currently sick of blowing 50-60A fuses, I don't often keep any spare, so it's a pain in the arse!
    Once every now and then if i have my stereo cranked and start the car, the fuse will blow .
    I bought a 60A inline circuit breaker to replace my fuse holder and will see how this goes!
    Anyone using a circuit breaker instead of a fuse? Opinions?
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Circuit breakers are quicker to reset, but really you shouldn't need to be reseting anything if your system is installed properly and has no issues.
    I use fuses because I trust them over circuit breakers.
    What size power cable do you have?
    00' WH Stato LS1 A4
    Dec 2008
    Adelaide, SA
    Only 8GA, I realise it should be 4GA but it only blows if i have the volume cranked and WHILST starting the car.
    When i upgrade (second sub, new monoblock, maybe new headunit) i'll just run 0GA.
    It's only blown twice since i had the system installed in early march, so not a frequent thing.
    acarmody is online now Donati..Whoa Green
    VX Berlina
    Apr 2007
    This is just a wild shot in the dark, as electronics isn't my best subject. But what are you using for the +12V remote power line. I thought that whilst the starter motor is engaged the car stopped power flowing to accessories. If you amp is still recieving power whilst the starter motor is engaging your electrical system may be 'spiking' and blowing fuses. Again I may be wrong.
    Ronald Reagan (1986)
    VYII Equipe S/wagon V6
    May 2009
    Melb, Vic
    Well not necessarily spiking but as the voltage falls to crank the car the amp draw increase's to the running amps.
    I personally wouldn't continue on this path of popping fuses/CB's as you will damage the amps as they are not clearly being supplied with the appropriate volt/amps.. Re-do the feed/s and always over estimate the max draw from the amp/s, plus I would consider at lease one cap to help regulate a stable volt/amp!!
    Cheers,
    Dave
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    VZS-Ute06
    Aug 2006
    Western Vic
    Cool
    (1) the voltage drops on start-up and the amp + devices in your car have to pull more current, My 1st guess is that your alternator is not up to the task of running all the accessories in your car this is why you are blowing your fuses.
    (2) My 2nd guess is the gain setting are set too high ! wind it back a bit,
    get a multi meter and mach the gain to the correct voltage from HU output
    VZ-Rob
    98 Ron Powerchip: CAI: SuperLows: GTS Swaybars: Tinted: SS Grille: SS Vents: SS 2:25 Twin Exhaust: ASR Audio:
    00' WH Stato LS1 A4
    Dec 2008
    Adelaide, SA
    Gain might be too high I think the headunit voltage output is 2V, (Alpine Electronics of Australia) Will check this out tomorrow! It's hard to get into my boot as I'm a fat arse and my amps are only accessible via crawling right in there. haha.
    The battery is OLD (4+ years), Pretty sure i could use some 4GA or bigger wire, though.
    Maybe i'll pull out the multimeter and check the voltage drop, i have had some minor headlight dim which i believe may be my battery. Probably more like the 8AWG cable, or alternator, though.
    VY SS
    Aug 2004
    SE Victoria
    mate it will be your wiring. I have had 2000 WRMS for the subs and 500 WRMS to the speakers and it has been fine with shitty old battery.
    What wiring have you done for the negative?
  1. Fuse or Circuit Breaker Problem :S
    By Connie in forum Electrical Wiring / Questions
    Last Post: 04-01-2009, 09:22 AM
  2. circuit breaker or fuse?
    By bangers in forum Car Audio
    Last Post: 14-09-2006, 08:19 PM
  3. Fuse or circuit breaker or both?
    By ozzietj in forum Car Audio
    Last Post: 01-06-2006, 07:32 AM
  4. Fuse Vs Circuit Breaker
    By mouce in forum Car Audio
    Last Post: 05-04-2006, 12:43 AM
  5. audio circuit breaker
    By matrix in forum Car Audio
    Last Post: 21-08-2005, 12:09 PM
