Results 1 to 15 of 15
Thread: VS Firewall Hole
    2005 VZ SV6
    Jun 2009
    Australian Crapital Territory
    Default VS Firewall Hole
    Hey Guys, Noob Question below:
    Where abouts is the firewall hole in a 96 VS to put the amp power through?? Also which is the best side of the car to run the cable from the sub to amp? (Amp will prob be under passenger seat).
    Thanks, Max
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    There is an oval shaped grommit next to the brake booster (passengers side of the booster when looking at it from the engine bay), remove that and punch a small hole in the carpet underlay, drill / cut a hole through the grommit and run your cable through it and the carpet underlay, it should come out near the brake pedal from the inside.
    Can i ask why you wanna mount the amp under the passenger seat? Its not a level place and air flow isnt the best either (ive got my speaker amp there in my VR).
    Anyway, its not important which side the speaker cable goes to the sub, so if you do mount it under the p/s seat then run it down the p/s.
    150db in a commodore =
    2005 VZ SV6
    Jun 2009
    Thanks mate, and what does the brake booster look like? hahaha, (Rough location when looking at the engine bay)
    Basically putting it under the passenger seat due to the fact that the wiring kit I have will not make it any further than there, if it even makes it there.. Haha.
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    The brake booster and master cylinder(silver thing in front of the booster) are on the drivers side when looking in from the engine bay. The brake booster will be directly in front of the steering wheel (again, looking from the engine bay)
    EDIT: This is not my car
    Attached Thumbnails Attached Thumbnails VS Firewall Hole-26008910009_large.jpg
    2005 VZ SV6
    Jun 2009
    2005 VZ SV6
    Jun 2009
    Hey mate,
    Had a go today, bit of a tight fit though.. Any tips on getting it through?? And where you reckon best place to earth is if the amp is under the p. seat??
    Thanks,
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    What through the grommit or the carpet underlay?
    My amp is earthed to one of the seat bolts, just put the ring terminal over the hole and replace the seat over the top (maybe get someone to hold the terminal in position) then put the bolt through and tighten it up. Make sure to sand back the paint around the hole you want the terminal to go onto.
    2005 VZ SV6
    Jun 2009
    Getting it through the grommit... Are you talking about the grommit that is unused? (sorta like its plugging a hole?) or the one that has a bunch of cables already going through it?
    Thanks for ur help mate, I'm new to commodores and well cars in general haha.
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Yeah the oval grommit thats unused (the car is auto i assume?). The grommit should be about 5cm x 3cm. Remove the grommit (just use a screwdriver to pry it out) and drill a hole in it about the same size as the cable, if youre having trouble getting it through then just get some soapy water or dishwashing detergent / water and "lubricate" the cable so in slides through better.
    Oh damn, that last part dosent sound so good
    2005 VZ SV6
    Jun 2009
    Haha now I'm with you I thought that mighta been it but didnt wanna go prying around random places haha. Thanks mate, Ill give it a whiz tomorrow arvo. Legend :P
    White Tiger's Avatar
    White Tiger is offline Semper Fidelis
    VN Executive Wagon VR Berlina V6
    Jul 2009
    Bordertown SA
    are there any other places you can run the cable through my vs is coloum shift and uses that hole for the shifter and i need a bit more bass out of my car
    Jul 2009
    Bordertown SA
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    I think someone said a while ago about using the speedo cable or something along those lines.....heres the thread. Read the 11th post, should be the same for you....havent checked this in my car.
    Jul 2009
    Bordertown SA
  15. #15
    2005 VZ SV6
    Jun 2009
    Hey guys sorry, Just got online.. arrived on the gold coast from CBR tonight I got in it with the above instructions, pullin out the oval grommit, shangin a hole in it and running it and cable-tying it to stuff Works a charm
  1. vs firewall hole
    By VSEXEC in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-05-2009, 07:05 PM
  2. more on this bloody gauge install, weres a good hole in the firewall?
    By PSYKO PHOENIX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2009, 01:52 PM
  3. Putting a hole in the firewall on a VX SS
    By bartman in forum Car Audio
    Last Post: 17-09-2007, 06:25 PM
  4. amp power cable, No hole in firewall. :(
    By phat_com in forum Car Audio
    Last Post: 02-04-2007, 11:45 AM
  5. getting a hole in a VZ ute firewall
    By CacTuar in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-12-2005, 02:59 PM
