Results 1 to 10 of 10
Thread: Amp Mounting
    greekplaya is offline Wog On Wheels
    VT Executive S2 Olympic Ediiton
    Jan 2009
    Adelaide, SA
    Default Amp Mounting
    Hey,
    I'm thinking about re-doing the boot in my VT slightly, nothing over the top just to add a bit more function.
    Currently I have the two amps attached to the back of the sub box. I was wondering though would it be alright if I were to get a piece of mdf and screw the amps to that and mount that to the rear parcel shelf. I'm not running any speakers in the parcel shelf and thought if I could do that it would free the sub box up for a little movement if I ever needed to use the split fold in the seat.
    Any thoughts or has anyone done this?
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    You mean put the amps on top of the parcel shelf? That's pretty much an invitation for anyone who has ever even considered breaking into cars and happens to walk past your car and see all your nice expensive equipment sitting up there proudly.
    Theres no real reason why it wouldnt work, but the simple fact that it would probably only last a few days is why noone does it
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    I think he means on the underside of the parcel shelf. If thats the case then there's no problems with doing it this way, i have done so many times where space or the ability to remove the sub box is important.
    150db in a commodore =
    Philthy's Avatar
    Aug 2005
    Ahh, well the underside would be the way to go. You will find one or 2 people say its bad to mount amps upsidedown but the majority (and people who know what they are talking about) say its ok.
    For the record, I've never done it or been involved in a system with upsidedown amps personally
    Jan 2009
    Adelaide, SA
    Sorry suppose I should said that I meant to the underside of the parcel shelf. I've also heard people talking about mounting upsidedown but most people seem to think it's not really an issue anymore (why I'm not completely sure but they know a lot more bout this than myself)
    holdenboy since you said you've done a few is there anything I should make sure I do or avoid?
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Not really mate, you can mount them upside down without any problems generally.
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    A bit like this?
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    Jan 2009
    Adelaide, SA
    that's pretty much exactly what I was thinking, have much trouble installing it all?
    danja's Avatar
    Jan 2006
    Nah, none at all. It's MDF covered with carpet. I used cardboard to trace a rough template, then after a few trial fits it was ready to bolt up.
    It mounts to the chassis using some long bolts, and aluminium braces to clamp it through the holes in the parcel shelf. I used 4 braces, which means it can carry the weight of 2 amps, and after nearly 12 months of spirited driving they are still as firmly mounted as day 1.
    Make sure you plan out where the amps will mount, so the controls are accessible and the wiring is sensible (try to avoid placing power cables next to RCAs etc).
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    As a general rule of thumb mounting the amps upside down is not an issue. After 10 years the only time I really see an issue arising from this is when the amp is running hard. Very hard and is loaded down to 1ohm....so basically the amp is flat out. Then it may overheat, this typically results in the amp shutting down for a period of time before powering back up.
  1. Replies: 0
    Last Post: 07-11-2007, 08:25 PM
  2. Sub mounting
    By Bubbles in forum Car Audio
    Last Post: 03-11-2007, 01:32 PM
  3. mounting h/u (vt)
    By SweetWagon in forum Car Audio
    Last Post: 18-10-2007, 01:52 AM
  4. mounting sub-box!
    By Troyziee in forum Car Audio
    Last Post: 23-01-2006, 05:01 PM
  5. Amp Mounting!
    By raZel in forum Car Audio
    Last Post: 22-09-2005, 07:29 PM
