Results 1 to 19 of 19
Thread: VS Ute speakers
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Default VS Ute speakers
    Im after a set of decent speakers for the ute. I want them to fit in the existing door pods (stock), I refuse to run a sub, but would consider an amp if its needed.
    Im not after loudness or a doof doof system, I mainly listen to country and rock, so mainly after a good sound with decent loudness to it.
    Budget is $300.
    I was looking at Alpines, but open to suggestions.
    Also what is the difference between normal speakers and splits?
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    CH Lancer
    Jul 2009
    The two main types of speakers are Coaxials and Splits. On a coaxial the tweeter is built into the speaker but in splits the tweeter and midwoofer are separated. This will typically allow for a better level of sound quality.
    I strongly encourage you to check out the following: http://forums.justcommodores.com.au/...-5-splits.html
    The review can be found here on Just Commodores: Audio development AD6
    They are a little over the budget you have in mind but when it comes to listening to rock music, having a good quality speaker is especially important.
    I would strongly recommend an amplifier for that set and for any set if you primarily listen to rock. For rock music to sound as it was recorded you need to have the ability to produce midbass and that requires power. Running splits off a head unit will limit its ability to produce the midbass to make rock sound realistic.
    Hope that helps
    Joe Bellissimo
    Shopping Secure - Car Audio Specialists
    www.shoppingsecure.com.au
    MSN/Email: sales@shoppingsecure.com.au
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    I'd defenialtely reccomend a set of splits, over coaxials. Particulary in a VS, being that the speaker pod is down relatively low, having the advantage of mounting a seperate tweeter up higher, means your able to project some of the sound upwards towards you.
    VZS-Ute06
    Aug 2006
    Western Vic
    Cool
    G'dat Tom 1569
    I run these on seperate amps
    they kick really good
    6.5" Precision Response Kevlar splits - Jaycar Electronics
    for the money you cant go wrong
    I listen to heavy R&B ie Stevie Ray V, Robert Cray etc
    This is where I mounted the tweeter
    Tweeter postitioning
    Then if you want a cheaper amp this really works well
    the Orion amps kick
    Car Sound, Car Amps : JB HI-FI
    VZ-Rob
    98 Ron Powerchip: CAI: SuperLows: GTS Swaybars: Tinted: SS Grille: SS Vents: SS 2:25 Twin Exhaust: ASR Audio:
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by Joe Bellissimo View Post
    Hope that helps
    Thanks for that, I did set a budget of $300 for speakers, mainly because I dont need anything over the top, more quality then loudness. Im slightly flexible, what sort of amp would you recommend to run the speakers you recomend. Thanks for the advice to.
    Quote Originally Posted by HoldenCommodoreVP View Post
    Thanks to, all starting to make sense now
    Quote Originally Posted by VZ-Rob View Post
    G'dat Tom 1569
    the Orion amps kick
    Cheers mate, that was my next question of where to mount the tweeter lol. For some reason Ive never been a fan of Jaycar speakers, and to this day I dont know why, but I dont like them lol, but thanks for the heads up, Ill still consider these.
    CH Lancer
    Jul 2009
    One of the steg amplifiers on my website would be the most apporopriate amplifier to run those speakers. That said, one of the cheaper ones would do just fine, I'm just a perfectionist
    Joe Bellissimo
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Im a perfectionist to, but Im also working on a budget as music isnt my main priority. The steg amps are definitly out of my range of what im willing to spend on an amp/setup. Would the speakers be alright running off the headunit, then if I dont like Ill consider an amp.
    CH Lancer
    Jul 2009
    Yeah they would work and they would sound good since they're great speakers. But they would sound dramatically better with an amplifier. You could always add an amplifier later if you wanted. If you do it in steps you can always stop once you achieve the quality you are looking for.
    Joe Bellissimo
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Sweet, thats seems like the go at the minute. Ill let you know when Im ready for a set (long term plans).
    CH Lancer
    Jul 2009
    Luke0011 is offline Car Audio Installer
    VZ Berlina 2005
    Jan 2007
    Hope that helps
    Seriously Joe how is one type of music (rock) especially important to have a good quality speaker. ???
    And any speaker produces midbass, and power isnt the most mitigating factor to produce a warm, rich and colourful sound moreover the speakers front and rear wave being isolated as much as possible and its angle of direction will reuslt in more efficiency thus creating the desired tighter and warmer midbass frequency response and less power needed to produce such warmer sound.
    Mounting the tweeter anywhere other than next to the woofer completly ruins the imaging and staging of sound and the frquency response ( sound quality ). Although yes it does project the sound upwards as it its up anyway.
    VZS-Ute06
    Aug 2006
    Western Vic
    Wink
    G'dat Tom 1569
    just put some 4" TX4001 mid splits in the kick panel $150au delivered
    Frq 74Hz-20kHz
    Power (RMS) 75
    Peak Music Power 150
    Sensitivity @ 2.83V 90dB
    together with the 6 1/2 Response splits in the doors
    Really kicks ass now
    IMO for the $$ the sound will blow the AD6's away anyday
    the set-up now is 6 1/2 woofer in the door pods
    4" woofer in the kick panels
    tweeters in the doors near top vent
    tweeters in factory position
    12" sub in tray
    seperate matched amps for woofes and tweeters
    amp for sub
    VZ-Rob
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Debate, I like debates. Sits back and listens
    Thanks VZ-Rob, Have you got pics of them mounted in the kick panel, I dont think it would be possible in the VS.
    Everyone else, Im still open to suggestions until i've bought a set
    Mar 2009
    Cairns White Rock
    Quote Originally Posted by luke0011 View Post
    IMO mounting the tweeter anywhere near the woofer sounds crap. Particulary when the woofer is mounted low down in the door, why project the sound upwards from around your feet, and also consider the difference in sound when carrying a passenger as oposed to being the only person in the vehicle. And i have to agree with Joe about a quality speaker when it comes to rock music, strong midrange is vital for that style of music, compared to say rap, or RnB where you can get away with just having a good amount of high's and low's.
  15. #15
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    I have my tweeters mounted down on the speaker pods in my VS, facing up towards me. I hate the fact that I have to have my leg in a certain position to get ideal sound. They were originally put down there temporarily until I did a fancy door trim, but that was about a year ago.
    After experimenting with positions a LOT, I will either be putting them in the stock positions or up higher on the door trim (possibly on the vents). These are type-x splits and the crossover is setup differently depending on the position of the tweeter in relation to the woofer/driver, so that helps with staging/response, although I don't always agree with the calculated crossover settings
  16. #16
    2000 VS Ute 5 Speed
    Oct 2008
    Western NSW
    Then you might as well just have coaxials. Is'nt the whole point of component speakers to get the tweeter away from the woofer?
  17. #17
    Mar 2009
    Cairns White Rock
    G'dat Tom 1569
    Frq 74Hz-20kHz
    Power (RMS) 75
    12" sub in tray
    amp for sub
    I have to say i tend to disagree a little bit with you there, about outperforming the AD's. In one way yes, you probably right, but consider a few things. The 6.5 inch driver from the response series, is not bad at all, for the money you spend, but it's nothing spectacular, easily outgunned by much more expensive speakers, though as it should be. Adding an extra 4 inch mid driver, is going to increase your midrange levels, but now have look at the tweeters that come with the Jaycar splits, i've personally installed set of these tweeters as a replacement for someone, and again for the money you pay, you can't go wrong, but i wouldn't rate them for their performance especially if your now running 2 sets of midrange drivers. The tweeters that came with my AD's, are what have impressed me so far the most. IMO your better of just buying a decent 2 way system , rather than building your own 3 way. But that's just my view on the topic, if it sounds good to you, then ofcourse that's all that matters..
  18. #18
    CH Lancer
    Jul 2009
    Rock music typically has a lot more going on when compared with rap and rnb. I find that when listening to music such as rock music a speakers shortcomings become apparent very quickly. I can appreciate that I'm simplying things a bit but generally speaking I have found this to be true.
    12" sub in tray
    amp for sub
    Hehehe, why don't you build that and put it up against my AD6? You will more than likely find it wont sound as good and end up costing more in the end
    Joe Bellissimo
  19. #19
    VZ Berlina 2005
    Jan 2007
    Missing the point in that what i was implying that its incorrect to especially have a good speaker for just one type of music. Its especially good to have a speaker for any type of music.
    And from a scientific point of view having the sound or frequencies of the sound coming from one point creates the best possible sound quality. And mounting a tweeter in the door with a bit of skill can be positioned so that it does not get in the way of your legs and improves the imaging and staging of the sound compared to it being high and away from the woofer in the door. But hey if you can get the woofer up high too then your laughing.
    Quote Originally Posted by VS ADDICT View Post
    Component speakers where not designed to move the tweeter away from the woofer. But more so to create better frequency reproduction from there respective speakers.
  1. Speakers - sub woofer vs 9 x 6 speakers
    By adelaide paul in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-01-2009, 11:15 AM
  2. VZ S ute speakers
    By murph_1989 in forum Car Audio
    Last Post: 21-12-2008, 09:31 PM
  3. Replies: 2
    Last Post: 04-09-2008, 08:18 PM
  4. Replies: 18
    Last Post: 06-01-2008, 07:09 PM
  5. Speakers ??
    By Jecs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-07-2005, 06:17 PM
