Results 1 to 15 of 15
Thread: sub cut out
    lion_g is offline LionG
    VT Executive Series II 3.8/V6
    Jun 2009
    T'Ville
    Default sub cut out
    Hey all.
    i got a standard vt with a jvc amp (1000 watt)
    and a kenwood sub 800 watts running 4 gague wire off a pioneer head deck.
    the bass notes play for a bout 2 seconds then the amp goes into surge and shuts off for a sec then back on again.
    any ideas?
    and yes i have checked, checked and checked the leads and they are all conected properly!
    i can have the sub working but the gain cant go past half way or it shuts off i have to have it down real low which isnt cool!
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    Did you sand back the paint at your earth?
    Also make sure all the bass boosts etc are off on the amp
    Jun 2009
    T'Ville
    yeahh i sanded it back its behind the back seats.
    all boosts are off on the amp.
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Get a multimeter and put it on the + and - terminals of the amp, while the car is running play some bassy music and note what volts the amp is getting.
    Do the same but with the multimeter on the battery terminals, if theres any huge difference (over a volt) then theres a problem with your wiring or connections.
    Generally, the voltage should stay about 11v while the car is running.
    150db in a commodore =
    Jun 2009
    T'Ville
    Philthy's Avatar
    Aug 2005
    VYII Acclaim
    Jun 2008
    Largs Bay, Adelaide, S.A
    Quote Originally Posted by lion_g View Post
    Hey all.
    You're not trying to fully power the amp off the remote line from the head unit by any chance? The remote line is only for remote switching of amps and/or antennas.
    + volts - - - Straight from your battery
    GND (0v) - - - Straight from your battery
    Remote - - - From head unit
    It may be a silly question, best to cover all areas.
    Good luck
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Post up model numbers of the amp and sub, plus the way it has been wired.
    Philthy's Avatar
    Aug 2005
    Quote Originally Posted by scozz76 View Post
    Good luck
    GND from the battery?? Earth it in the boot somewhere.
    Holden VE SV6 Ute
    Jan 2009
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Yeah its ok to earth straight from the battery, but really unnecessary. You will get just as good as a connection if done properly in the boot etc.
    VYII Acclaim
    Jun 2008
    Quote Originally Posted by Philthy View Post
    This is basically straight from the battery!!!! If I had written "earth somewhere in the boot", it may create confusion for some people. I'm not intending to put down LionG, just keeping it simple.
    Don't worry about picking my post apart, concentrate on the original problem!
    Philthy's Avatar
    Aug 2005
    Sorry, wasn't having a go, but to me your post said "run a ground wire direct to the battery" and was just trying to avoid confusion
    VYII Acclaim
    Jun 2008
    No prob's, all good!
  15. #15
    CH Lancer
    Jul 2009
    Did you get the model numbers yet?
    Joe Bellissimo
    Shopping Secure - Car Audio Specialists
    www.shoppingsecure.com.au
    MSN/Email: sales@shoppingsecure.com.au
