I just installed a new head unit into my vx, but i cant get the aerial working. how do they work? there are a few left over wires, but im not sure which ones are the aerial. and where do i connect these wires? Can i connect the aerial to accessories power so every time i turn accessories on the aerial comes up? or hows it work. thanks.
Australia. Love it or leave it
I'm not sure of the factory colour code for the antenna, but you apply +12v to it. You should find a wire on your H/U labelled 'amp remote' or something like that, it will supply the volts for your antenna.
Do a search for the colour codes.
VK-VZ Stereo wiring colours.
This is a list of what the wires in the car do. match them up to the new unit and you should have success.
Yeah i already looked at that tread. antenna up and down white and blue wires, but there are no white or blue wires in my car?
The white and blue wires are not the ones. That's for units that have manual up and down controls.
Yellow/Red is the one you wire to.
for more info, go to http://www.eurovox.com.au/downloads/...m%20Update.pdf
I know it says vn-vt, but from my understanding, it has stayed the same.
Thanks man. I didnt know the white and blue were for manual up and down. i was wondering why i didnt have white and blue wires haha. i wired the yellow/red up to the remote wire (thinks thats what its called) that usually turns my amp on. havnt wired my amp up yet so hope i can wire both to the same remote wire.
thanks everyone
As long as you stay below the max current, you'll be fine. If in doubt, wire a relay to the remote wire to switch another 12v line.
^^^ You could either do that, or wire the antenna or amp straight to accessories. The only real difference is the component you wire to accessories wont turn off / go down when you turn the head-unit off via the power button.
150db in a commodore =
anyone know how much the aerial and amp would draw on the remote wire? Just read my remote wire is only 300mA
Not too sure, but the amp and antenna should pull more than that i would imagine. If you know what your doing it's a good idea to use a relay to turn on the amp / antenna, if not just wire the antenna to accessories and if you like you can add a switch inline to retract the antenna if youre listening to CDs etc![]()
now that i think about it, i might even wire it up to an accessories power, and wire up a little switch because at the moment, even if listening to cd's the aerial stays up
haha we wrote pretty much the same thing at same time haha
