Like the title suggest, I'm chasing a new headunit, but it HAS to have several features and I can't find what I'm looking for. Perhaps some of you might know of a unit that will cover me?
Double Din
Built-in Bluetooth. (not add on unit unless it allows 10key dialling)
USB (rear, not front stuff)
6ch RCA
Would prefer over 4 volts as the new system is going to be running a total of five amps so would prefer to have a lot of grunt down my signal lines. If I have too....I will use multiple line drivers but would prefer not. But either way, it will be going through active crossovers just prefer to have plenty of grunt like I say.
Oh and when I say Double Din....I do NOT want a touch screen!
Any ideas guys? Am I pushing shit up hill? All suggestions will be listened too! Help a bloke out here!
If you went single din, What you want = Do-able,
If you went double din, Touchscreen, What you want = Do-Able
However, Double Din, Non Touchscreen & 3pair RCA out = Impossible to find, let alone bluetooth & rear usb.
MaT
Originally Posted by garth
I realise this...the closest I've found so far was a sony unit...had USB and 6ch rca out but no bluetooth. Seemed like a nice unit as well.
Are you trying to avoid the touchscreen because it'll be more expensive? I'd say It's pretty unlikely. Might have a bit more luck with single din and fold out screen?
5 amps... Running? Unless you're running each corner off it's own amp, That's a lot of subs.
Pioneer FH-P80BT sounds like what you want.
DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
Originally Posted by Reaper
Companies don't put much effort into double DIN CD players
Pioneer FH-P80BT.
Double DIN, built in BT, rear USB, 3 sets of 4v RCA. The extra voltage is not necessary unless your car has lots of electrical noise in it.
Ryda Car Audio - Pioneer FH-P80BT Car USB MP3 Tuner($699.85)
$700 from Ryda (in sydney - they post aus wide - sydney to melbourne only took 1 day 18 hours.)
very happy with them.
lol, I had forgot all about that pioneer unit! Have actually used it before! It's not bad at all. I believe it's no longer available but I can still get it. No way am I paying $700 for it though![]()
