Results 1 to 9 of 9
Thread: Hooking up 6x9's.
    chrism182's Avatar
    chrism182 is offline VX S Pack
    VX S Pack M5
    Sep 2008
    Victoria, Australia
    Default Hooking up 6x9's.
    In my car, I currently have an amp and a sub installed with the stock in-door speakers. I have got 2 6x9's and I'm looking to install them. How do I go by it? Do I run the 6x9's off the headunit or the amp? The 6x9's are already in enclosures so do I just hook a white speaker cable up to it?
    Any help would be great.
    Cheers,
    Chris.
    eziautoparts.com.au
    Your total auto parts store on the web!
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    If you really want to install them (in my opinion 6x9s are only good if you dont have / want a sub), i would remove the rear parcel shelf and "prize out" the peices of sheet metal on either side, they are perfect for 6x9s. You will need to cut the holes out of the parcel shelf (the top piece) then buy a set of commodore parcel shelf grilles.
    150db in a commodore =
    chrism182's Avatar
    VX S Pack M5
    Sep 2008
    Victoria, Australia
    Yeah that's where I was planning to put them, need help on more of the hooking them up side though.
    Thanks,
    Chris.
    eziautoparts.com.au
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    What sort of amp are you using?
    Usually most people would say you don't need 6x9's and a sub, but since you already have them, piss off the enclosures and mount them as flush as you can on the parcel shelf without cutting any metal, then hook them up to either the headunit or amp depending on the amp.
    I'm not sure how much room there is under a VX parcel shelf
    EDIT: Holdenboy beat me to it
    chrism182's Avatar
    VX S Pack M5
    Sep 2008
    Victoria, Australia
    The amp is an aXis 400W 4 channel amp and the head unit is a Clarion CX609A (High power 50W x4).
    eziautoparts.com.au
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Edit: OK then just run another pair of RCA cables from your head-unit to the amp and connect the 6x9s to the amp....
    chrism182's Avatar
    VX S Pack M5
    Sep 2008
    Victoria, Australia
    Philthy's Avatar
    Aug 2005
    Yeah, you should have 2 spare channels on the amp, so run the 6x9's off them. You will need to run extra RCA's from the headunit as Holdenboy said
    chrism182's Avatar
    VX S Pack M5
    Sep 2008
    Victoria, Australia
    Thanks again, I'll probably do it one day when I'm bored as I didn't install the head unit and I don't feel like undoing everything to get to the back of it.
    eziautoparts.com.au
  1. hooking up 2 amps
    By joshy123 in forum Car Audio
    Last Post: 20-08-2009, 12:18 AM
  2. Hooking up 6x9 speakers to an amp.
    By chrism182 in forum Car Audio
    Last Post: 30-05-2009, 12:33 PM
  3. hooking up lights
    By miltiadis_s in forum Electrical Wiring / Questions
    Last Post: 16-07-2008, 08:32 PM
  4. hooking up an alarm
    By Jazack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-02-2008, 01:32 AM
  5. Hooking Tacho Up!!! Help Me!!!
    By SiLeNt-SoN in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-09-2006, 05:55 PM
