Hi Guys! The rear speakers in my VR have blown, and being factory 15W, am looking at replacing with 190W 6" Sony speakers. Any tips out there. I haven't needed to do this before...![]()
My only tip would be not to buy the Sony speakers... If you haven't already bought them, listen to some other brands.
I only got 'em on the cheap... $54 for the pair... ugrading to VE early next year
For best results: Put the stock speakers from the front into the parcel shelf, then the new ones into the front as they will sound better.
But if you don't care about your stereo and just want something that will work: you will need to pull the rear seat out to get to the parcel shelf, then just pull the stock ones off, cut off the plugs, SOLDER on the new wires with the connectors, then screw the new speakers in (might need to use the adaptor plate they should come with). Pretty sure that is the most simple way...
Thats a basic run-down, if you need more detail on any parts then let us know
I've already got 190W in the front... Thanxs for the tip guys... I'l get cracking... here's to a win @ BATHURST. Go HRT!!
