Results 1 to 14 of 14
Thread: Twin Subs distoring after wiring change?
    GMHCalais is offline [TUKN20Z]
    VY SII 5.7 Calais, VS SS SII HSV Enhanced
    Jul 2009
    adelaide yo
    Default Twin Subs distoring after wiring change?
    so i moved my sub box with the twin subs in the boot. i had to take the subs out to get to my 6 inch speakers. in the process i unwired the subs with the power off.. mucked around with my amp settings ie hi/low pass and the gains, frequencies and the rest. and now my subs arnt half as loud and they distort when i try to fix the problem with my amp...
    im running my cadence Q12-2 subs and front splits off a cadence 4 channel Q drive amplifier..
    none the less i was wondering if anyone could help me with this problem..
    cheeers in advance..
    Slammed 5.7 VY calais II tuckin G8 20'z
    CH Lancer
    Jul 2009
    If they have been wired up excatly how they were before you took them out then you have made an error with the amp settings.
    On the amplifier make sure the gain settings are set to MIN and the bass boost is set to MIN. Set the crossover to LPF (Low Pass Filter) and also set that to MIN. Use that as a reference point and tune from there.
    Joe Bellissimo
    Shopping Secure - Car Audio Specialists
    www.shoppingsecure.com.au
    MSN/Email: sales@shoppingsecure.com.au
    Jul 2009
    adelaide yo
    Quote Originally Posted by Joe Bellissimo View Post
    should there be an exact way to wire them up? as the installers used the same coloured wiring for both subs.. therefore me getting confused..
    i believe theres two positives from the amp to the sub. and then a separate piece of wire that goes from the negative of one sub to the other.. that make sense/sound right?
    CH Lancer
    Jul 2009
    Take a picture of it when the sun comes up, that should put us all on the same page.
    Joe Bellissimo
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Quote Originally Posted by GMHCalais View Post
    Two positives? If your subs are linked in the middle, they're wired in series. The amp would be bridged across 2 channels to run those subs at 4 ohm.
    There should be a positive and negative wire to the amp. You'll need to look at the amp or the amp's manual to find out which terminals to use when bridging.
    Jul 2009
    adelaide yo
    Quote Originally Posted by StoneX View Post
    theres a wire that doesnt go to the amp at all.. it was just connected from one negative on the sub. to the other negative on the sub.. with the two wires coming from the amp going into the positives on each sub..
    i havnt got the manual. as my system got custom installed and they didnt give me the manual etc..
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Jul 2009
    adelaide yo
    Your wiring is wrong. It should be like below (except your subs are 2 ohm):
    would this be the reason my subs are performing so poorly? or would my amp have something to do with it..
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Edit.....StoneX you beat me
    Anyway yes i could well be the reason why the subs are performing poorly, rewire them like the pic and see how that goes.
    150db in a commodore =
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    From your description you have the negatives linked and then the positives to the amp... Having the negatives linked means the speakers are out of phase for starters so the subs are moving in opposite directions and making hardly any bass.
    Then you have the 2 positives connected on the amp, this is not usually how you bridge an amp so you're probably linking 2 channels that shouldn't be linked. You need to find out how your amplifier is meant to be bridged.
    What model amplifier is it?
    Jul 2009
    adelaide yo
    model is a Cadence Q4100
    i found the specs on the net =
    4 x 75W @ 4 ohm,
    4 x 125 @ 2 ohm,
    2 x 250W 4 ohm Bridged
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Manual is here: http://www.cadencestore.com/cadence_...p%20Manual.pdf
    How the sub should be wired is below. See you use the + and the - on the amp, not 2 +'s.
    Attached Thumbnails Attached Thumbnails Twin Subs distoring after wiring change?-q4100.jpg
    Jul 2009
    adelaide yo
    thanksss so much, shall try that tomorrow when its sunshine!
    Jul 2009
    adelaide yo
    re wired the subs up & fixed the amps settings up.everything works a treat now! thankyou to everyone that contributed to me fixing it..
  1. Wiring Subs Down From 4ohm to 2ohm??
    By sweefu in forum Car Audio
    Last Post: 16-07-2009, 05:12 PM
  2. SA:FS/SWAP Twin 12" Us Audio Subs
    By Kyle23 in forum Parts And Other Items For Sale
    Last Post: 07-08-2008, 09:35 PM
  3. wiring twin au thermos to ecu
    By sebstenator in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-04-2008, 01:17 AM
  4. Wiring 2 subs to a two channel amp
    By InsaneSlug in forum Car Audio
    Last Post: 15-06-2005, 06:06 AM
  5. Amps/Subs/Speakers wiring
    By tr3nt in forum Car Audio
    Last Post: 07-07-2004, 12:37 PM
