Results 1 to 7 of 7
Thread: Radio stays on after key removed from ignition
    2005 Commodore Lumina
    Oct 2009
    Default Radio stays on after key removed from ignition
    Hi all, first time poster. I drive a 2005 Commodore Lumina.
    95% of the time when I removed my key from the ignition and open the driver door, the radio/ CD player will cut out.
    However from time to time I notice that the radio or CD player will stay on after I remove the key and open the door, and even after I have gotten out and locked the vehicle.
    Is this normal behaviour for this model? Is there a setting that I have inadvertently activated?
    If this is not normal can anyone suggest where the solution lies. Electrical fault?
    Thanks
    Chris
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    I'd be looking at a faulty door switch, try changing it with the passengers side switch and see if that fixes the problem
    Power is measured in DECIBEL
    Vy tonner
    Oct 2009
    Mine does exactly the same! If you turn the car off, I can often hear a relay clicking under the dash and the radio will be turning off and on again until it finally finishes on one (usually on). Pretty crap cos the wipers are also hooked up to the radio power circuit. So if you get out quick and hit the buttons, it comes back on later and you come back to a car with radio and wipers ON!
    I have an aftermarket sony phone kit installed in the car. No prizes for guessing what the dealers said causes it when I asked them about it. I have had one sparky tell me that the fault could also be in the radio. Im wondering if changing the headset (want to get an aftermarket bluetooth one with AV input if poss) will maybe sort this out.
    Anyone come across this before? Seems weird...
    VYII Equipe S/wagon V6
    May 2009
    Melb, Vic
    You may need to put a diode inline on you ACC feed to the radio as any load fault to 12v- will trigger the the ACC to stay on
    Cheers,
    Dave
    Blown VS Calais !!
    Jan 2005
    Kalgoorlie WA
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    would probably tend to agree with Kal also. One thing that will help point to it is if the fan on the AC continues to run also...
    VR GTS
    Oct 2009
    will the fan be on the radio circut? i know in earlier commodores the fan was only on with the ignition on, might have changed though, dont know.
    yea, if other stuff is turning on, or staying on, such as wipers or interior light or any other accesories thing (cigarette lighter maybe) then its something with the car, wiring or ignition barrel or any number of things, if its only the headunit coming on, and nothing else at all, then it could be just the headunit playing up.
    from memory, there is a setting for leaving the radio on without the keys, but it should be consistant, eg, always stay on, or always go off. i remember mums vy having something like this, but it was awhile ago...
  1. Ignition key can be removed whilst driving
    By Holdfast in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-06-2008, 03:54 PM
  2. VG Ute problem: cd player, tacho stays on when key is out of Ignition??
    By zacatrain in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-05-2008, 05:39 PM
  3. Vs Died After I removed Radio
    By masika in forum Electrical Wiring / Questions
    Last Post: 28-09-2007, 08:15 PM
  4. Fuel Pump Stays On When Ignition Is Off
    By sparkles_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-12-2005, 10:48 PM
  5. Blower Fan Stays On With Ignition Off.
    By gsmrobinson in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-10-2003, 01:07 AM
