can anybody help me im trying to find out what colours the wires for the speakers in the doors of an ve sv6 comodore ute? also where abouts the plug is located on the head unit.
Alrighty the plug is located on the drivers side of the head-unit, you need to remove the side plate of the centre console (beside the head-unit).
Wiring colours:
Left Front - Grey(-) Brown(+)
Right Front - Dark green (-) Light green/Black(+)
150db in a commodore =
Sozz I'm not sure you may need to pull the lining off and have a look then post your results.. I would think that there's no plug as such with the VE's as it would be fixed into the body of the dash.
Cheers,
Dave
thanks for the help guys
also does the standard tweeters go from them wires to a crossover or do they wire straight to the head unit?
There is a plug on the d/s of the head-unit, it has the speaker / power wiring there, just look for those wires and you'll be right.
I think the tweeters join onto the speaker wiring somewhere in the dash, the "crossover" for them is just a small capacitor or something thats attached to the tweeter itself.
cool thanks again.![]()
