Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: Which one is better
    holdendude's Avatar
    holdendude is offline ŞuρξЯŞ†★Ř
    *AL4SHO* VR Commodore
    Mar 2009
    Geraldton, WA
    Exclamation Which one is better
    Hey everyone, Im new to this audio thing and dont a much, would you be able to tell me which amp is better??
    1st one:
    Never used Currently at $51 on ebay.
    Fusion Encounter Amplifier- 2 Channel, 300W, EN-AM30020
    Peak power output 300W
    Frequency response 10Hz - 40kHz
    2ch x 70w RMS @ 4 ohms
    Bridged: 1ch x 180w RMS @ 4 ohms
    High and low pass filters
    2nd one:
    Used Currently at $49 on ebay.
    CLARION APX-4240 4 CH 240W AMP
    400 Watts of Maximum Music Power
    60W × 4 Into 4 Ohms, 20Hz-20kHz @ < 0.1%THD
    90W × 4 Into 2 Ohms, 20Hz-20kHz @ < 0.1%THD
    Selectable Bass Boost; 0dB/6dB/12dB @ 50Hz
    Independent Front/Rear Adjustable -12db/Oct. High/Low Pass Crossover, 50Hz-300Hz
    Gold Plated Connectors; RCA/Speaker/Power
    Speaker Level Inputs
    Dimensions 13" × 10 7/8" × 2 3/4"
    Here's some pics...
    Attached Thumbnails Attached Thumbnails Which one is better-bd-7fu-b2k-kgrhqqokjyeq3qfdh-5bk4qh30mpw-_35.jpg   Which one is better-qro_56721_1.jpg
    VZ Executive BT-1
    Nov 2008
    HoldrodeoLT's Avatar
    HoldrodeoLT is offline I have no lemon pledge...
    2004 Holden Rodeo RA LT, 2008 Polaris Hawkeye 300
    Aug 2008
    Id say second one.. i think ive had that exact fusion amp and it was nothing but trouble
    Sway_OnVY's Avatar
    Sway_OnVY is offline Its a swan
    VY Exec S2
    Oct 2009
    South Side Adelaide
    Fusion stuff seems to have really gone down hill, i had a fusion amp running to fusin 12's, first the amp blew, then i got a kicker amp and it killed the subs. So now i have two clarions and seems to work well, so id say second one too.
    holdendude's Avatar
    Mar 2009
    Geraldton, WA
    Quote Originally Posted by =bullet40= View Post
    what do you need the amp to power?
    A subwoofer, its a Clarion 12" but not sure on the specs, as i havn't got it yet.
    I think, but dont quote me on it, its:
    Single 4-ohm voice coil
    Music peak power (W) 700
    Continuous power (W) 250
    Toyota MR2
    Feb 2008
    Neither??
    Find a Mono with ~250W (slightly more if possible). Could get a 2channel and bridge to make ~250W.
    250W is what your aiming for, slightly more on the amp so you give the amp some headroom and not clip. My quick 2cents.
    Deck: Alpine 9887
    Speakers: Hertz HSK165 XL
    Amps: Audison SRx2, SRx4 & Alpine M350
    Subs: 2x Alpine 10" Type S
    VZ Executive BT-1
    Nov 2008
    neither of those amps a prime for running that sub. i know the fusion amp, as that is what we use to power the subs at work and it really doesnt have that much power behind it , yes it will run it BUT to get the most outta that sub you'd want AT LEAST! 250w rms. have you had a look at the jaycar gear? thats what i run and it will leave you enough leeway to upgrade the sub at a later point and its reasonbly priced !!!
    (Jaycar Electronics - Better. More Technical.)
    VP Calais 5ltr
    Sep 2009
    West Melbourne
    If the fusion says never used but coming from a private seller, would not trust it.
    I have been out of the audio game for a hell of a long time now. But from quality wise I would def say the clarion.
    But if you want to do it properly and not twice I would follow advise given by Deutscher.
    INNAWE (in awe)
    Noun 1. awe - an overwhelming feeling of wonder or admiration; "he stared over the edge with a feeling of awe"
    2. awe - a feeling of profound respect for someone or something; "the fear of God"; "the Chinese reverence for the dead"; "the French treat food with gentle reverence"; "his respect for the law bordered on veneration"
    CH Lancer
    Jul 2009
    Are you planning a budget build or is this going to be a permanent system. I'm a firm believing in the moto "do it once and do it right".
    Joe Bellissimo
    Shopping Secure - Car Audio Specialists
    www.shoppingsecure.com.au
    MSN/Email: sales@shoppingsecure.com.au
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Firstly are you installing this in a Commodore? I personally wouldn't bother purchasing either of those 2 amps. A 250watt RMS sub, in a vehicle the size of a Commodore, is going to do SFA( and that's giving it 250, which those amps won't). Maybe whilst your stationary it may be audible, but once underway, the extra intrusion noise will most likely drown it out completely. IMO, you'd be better of upgrading your front stage.Subs can sound great in the right application, when installed and tuned properly, but i'd be more inclined to spend my money on something more suitable for day to day listening..My 2 cents..
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    It'll sound fine if you just want a little bass to support your speakers. If you want booming bass, you'll need something different.
    And I'd buy neither of those amps. You want at least 250W for it. Ignore the recommendation of a monoblock as they're not made to run 4 ohm subs.
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Quote Originally Posted by HoldenCommodoreVP View Post
    My first sub had a huge 160wrms and I still found it awesome. Never a problem with hearing it. It wasn't car rattling bass but it complimented the song nicely.
    Ronald Reagan (1986)
    CH Lancer
    Jul 2009
    OT: My first one was 160rms as well, grew out of that quickly...
    Joe Bellissimo
    VE Calais-V 6.0L
    Aug 2005
    Hastings
  15. #15
    VX Berlina
    Apr 2007
    Yeah it didn't last long before I got 400wrms of pioneer mono, then 700wrms of Cadence then 1400wrms of Cadence. If only I'd followed your motto at the start Joe.
  16. #16
    CH Lancer
    Jul 2009
    Quote Originally Posted by StoneX View Post
    Mine was 150W and one of the louder subs I've had.
    I think you have topped them all with your recent purchase :P
    Quote Originally Posted by acarmody View Post
    I wish I had followed it when I was younger! Now its my job to protect others from our mistakes! lol!
    Joe Bellissimo
  17. #17
    Mar 2009
    Cairns White Rock
    I wish I had followed it when I was younger! Now its my job to protect others from our mistakes! lol![/QUOTE]
    where were you when i had an 8 inch tornado sub in the bottom draw of my desk, hooked up to a home stereo
  18. #18
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    Quote Originally Posted by Joe Bellissimo View Post
    i know, we had a big convo on it
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
  19. #19
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    Quote Originally Posted by holdendude View Post
    1st one:
    2nd one:
    Here's some pics...
    i just got pioneer 2channel 300w amps for 50$ brand new at JB HIFI, were 180 each just because i bought a pair of speakers that were on sale.. keep that in mind
  20. #20
    VX Berlina
    Apr 2007
    Oh crap someone mentioned JB Hi-Fi, everyone, duck'n'cover!
  21. #21
    Mar 2009
    Cairns White Rock
  22. #22
    CH Lancer
    Jul 2009
  23. #23
    VX Berlina
    Apr 2007
    Boss FTW!!!
  24. #24
    CH Lancer
    Jul 2009
    Boss... I should import some American Boss and see how it performs.
    Joe Bellissimo
  25. #25
    VX Berlina
    Apr 2007
    Nah just hook them up to your test bench and run like 0.5 ohm through the amps and triple its max rating for the subs, literally kill em with fire.
