Results 1 to 6 of 6
Thread: Another "find that whine" thread
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    Default Another "find that whine" thread
    Hey, I have slight engine noise coming through the rear speakers only, that I set about fixing today, but have just hit a wall.
    Things I have checked:
    - All RCA connections, and proximity to high-current cables
    - Different set of RCA's (run down the centre of the car straight to the amp, away from ALL cables)
    - Swapped F/R RCAs over at headunit end so it is sending front signal to rears
    - 2 new earth points (all sanded to bare metal)
    - Swapped channels on the amp
    After everything I tried, the noise is ALWAYS out the rear speakers, fronts are always fine. So correct me if I've missed something obvious, but as far as I can tell, its not the RCAs, headunit, earth, or the amp itself. It must be post-amp, but the noise is in each rear speaker equally, and both are wired direct to amp with good speaker wire.
    The whine is only while the engine is running, and the pitch increases with engine revs
    Fronts and rears are running of the same 4ch amp, speakers are Alpine type-s coaxials, headunit is a JVC-AVX2 (pretty sure thats the model, I'll check in a minute)
    CH Lancer
    Jul 2009
    Does the whine still come through with the RCA cables removed?
    Joe Bellissimo
    Shopping Secure - Car Audio Specialists
    www.shoppingsecure.com.au
    MSN/Email: sales@shoppingsecure.com.au
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Philthy's Avatar
    Aug 2005
    Changes in pitch when i rev the car, and no, there was no whine when RCAs were disconnected
    CH Lancer
    Jul 2009
    Why don't you try moving the amp to a different location.
    Joe Bellissimo
    Philthy's Avatar
    Aug 2005
    Thats the 1 thing I didn't try. But does it explain the rears being the only ones whining no matter what signal they get or amp channel they are run off?
    EDIT: Too quick to hit reply! I meant to add that the amp is under a false floor that I just put back in coz I need the car tonight, so testing most things that I haven't already done will have to wait a day or so
  1. Official VY "Suspension + Wheels Setup" Thread!
    By nEb. in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-08-2010, 06:26 AM
  2. "find your posts" button???
    By savage1987 in forum The Pub
    Last Post: 06-08-2008, 09:30 PM
  3. Replies: 47
    Last Post: 12-02-2008, 01:03 PM
  4. Where is this thread? "Keep your radio on until you open the drivers door"
    By ozzie_online88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2007, 04:33 PM
  5. Replies: 29
    Last Post: 08-12-2006, 01:26 AM
