Results 1 to 6 of 6
Thread: speaker help
    VT Executive
    Nov 2008
    Default speaker help
    i recently bought a pair of fusion 6.5" powerplant splits and 6.5" reactor 3 ways
    i have a alpine 4 channel amp that gives out
    4 x 50rms
    or 2x100
    no
    im not sure if i shud give all 4 speakers 50rms or give the splits the full 100 and runn the 3 ways off the head unit
    the head unit is a pioneer and gives out 22rms
    i want it to be loud but not distort
    thanks
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    Are they the 120wrms splits? If so then definately give them the full 100w
    VT Executive
    Nov 2008
    so headunit power will be enough for the 3 ways
    the splits are 120 rms while 3 ways are 100 rms
    also whats this 88db and 91db meann
    Philthy's Avatar
    Aug 2005
    You should hardly hear the rears anyway, so you might as well run them off the headunit so you are getting the most out of the fronts. 100wrms really isn't even enough for the splits
    88dB and 91dB are the speaker sensitivities or efficiencies. Don't quote me on this, but the speakers are fed 1w @ 8ohms (2.something volts) and the SPL output is measured at 1m.
    Basically, the higher the number the more efficiently the speaker converts the power into sound, and the louder it will be with less power. So, the 91dB ones will be louder than the 88dB ones if you feed them the same power.
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    If the amp in question, delivers 50 RMS x 4, wouldn't it put out more than 100 RMS x 2, when in bridged mode? what is the model number of the amp?
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    I agree with HoldenCommodoreVP, it should put out more than double the power when bridged, most amps I've seen create four times the power when bridged then the single channel alone, working with 4 ohm here.
    Ronald Reagan (1986)
  1. speaker help please
    By kazalex in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-06-2009, 07:59 PM
  2. speaker help please
    By kazalex in forum Car Audio
    Last Post: 14-05-2009, 10:38 PM
  3. WTD - VS etc Speaker Door Pod Speaker Grills
    By lil_oneblue in forum Swap / Wanted to Buy / Trade
    Last Post: 08-01-2007, 08:38 PM
  4. speaker
    By ab56452001 in forum Car Audio
    Last Post: 04-01-2006, 08:28 AM
