Results 1 to 19 of 19
Thread: vk front door 6"
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    Default vk front door 6"
    hey
    I have some Cadence 6" splits and i want to know, how do i install them in the front door??
    i have 2 MDF rings and thats it
    thanks
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Well firstly your going to have to cut a hole in your door trims. Do this by placing the MDF ring you have, onto the door trim, and tracing around the inner circle.(but don't cut yet!!) You going to have to measure the mounting depth of your speaker, and make sure that the MDF ring you have, is going to give you enough clearance between the speaker magnet, and the inner door,( i will cover this) you may have to use additional rings, to gain enough clearance. Also be sure that your windows still go up and down, with out making contact with the speaker. Also make note of the manual window winders, and be sure that they will have sufficient clearance once the speaker is in place.
    Your going to have to run some speaker wire, from either you amp (are you using one) or from your headunit. I wouldn't reccomend using any original wire either, i'd be using new wire. You will need to find somewhere in the door, most commonly you will find a gromet on the inside of the front door,around the hinges, but not being familiar with VK's, you may have to drill a hole, in which you can feed the wire through. Make sure you make some sort of effort to cover the wire whenever you run it through bear metal, as over time, it can rub though the coating on the wire, causing you all sorts of problems.
    Next up, you going to have to remove your door trim, starting with any exterior peices such as window winders, door handles, and any locking mechanisms that are visible form the inside. Once your trim is off, you can make the cut that you traced out previously. You can also proceed to run your speaker cable through the door, and again, take note of any moving parts that may interfere with the wiring, and ensure they will not come into contact. Now is probably the best time, to run your windows up and down, and check that you are going to have enough clearance.
    Now that you have cut the holes for your speakers, ran your wiring, and double checked everything, you can mount your MDF rings to your door trims, by drilling a pilot hole from the inside from your trim, into the MDF ring. A pilot hole is essential as the trim will push away from the ring as your begin to screw them together. Once completed, i suggest using some silican sealant, around the inside edges, (do this on both sides of the door trim) to help seal any air leaks, and also help with strengthening once your speakers are mounted.
    You can then attach your speaker wire to your speakers, having plenty of slack at both ends will make this easier. You are now ready to mount your speakers the MDF rings. Place the speaker up against the MDF ring, and mark out where your screws are going to go.Make sure they are not going to come into contact with the screws you used for mount your rings.
    From then on it's a matter of re-assmebling everything, in opposite order as to how it came off. Remember to mark each wire on both sides as pos, or neg, or write it down somewhere as your working, so you don't get mixed up once your trim is back on.
    That's your mid drivers done, next you can move onto your tweeters and crossovers, which i won't cover now, as it's too much to write, but i can assist with that part when your ready. If you have any questions, feel free to ask, and i will do my best to help you, otherwise, their are plenty of other members, who will be bale to help you through it.
    Mar 2009
    Cairns White Rock
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Quote Originally Posted by HoldenCommodoreVP View Post
    weren't both these threads by you?
    Yeah i saw this thread.....i dont really like repeating myself lol
    150db in a commodore =
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    hey
    best way to install speakers in vk door i mainly didn't understand because we had people going on about making fiberglass pods and so forth so no you did not waste your time on this. this has made a heap more sense to me than those other threads..
    look.. thanks for this. ive got exams on now no the simpler ^^ it is (which it is) the better cause i have exactly 1,000,001 things going through my head at the moment
    thanks
    vk.jonno's Avatar
    vk.jonno is offline :):):)
    Vk commodore, hq one tonner, hj ute,
    Nov 2009
    south east
    i just got a angle grinder and a permanent marker and attacked my door
    Quote Originally Posted by BIGbrown1 View Post
    Hey dea, financed my VS 3yrz ago, desper8 4a car, meter read 214,016kms... I PAID $14,000.00, 3yrz l8r im dealin with alot of problemz... n e cheap BUT good mechanix in west melbourne? n e info appreci8d... Fanx...
    Quote Originally Posted by Menace38L View Post
    yea if i end up getting it il lay low from the cops lol jus want it for skids etc lol
    Mar 2009
    Cairns White Rock
    HSV VXII XU6
    Nov 2009
    Does anyone know the best way to set up a sound system in my HSV vxII xu6
    Mar 2009
    Cairns White Rock
    Quote Originally Posted by Mounge View Post
    Your going to need to be a lot more specific than that. What are we talking about? Tuning of the factory system, or advice for a new build up? Oh, and you might want to start a new thread, that will get you more replies...
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    Quote Originally Posted by vk.jonno View Post
    ill go for the more subtle approach, MDF rings
    vk.jonno's Avatar
    Nov 2009
    south east
    because some vk doors didnt have door speakers or holes in the actual door for speakers.
    that is the point of the angle grinder
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    ahh.. i understand, ill pull off the door trims when im with it again and see the doors and see if there are the holes there
    thanks
    vk.jonno's Avatar
    Nov 2009
    south east
    some of them do
    mine didnt lol ohwell.
    they do now
    good luck man
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    A Jigsaw with a metal blade in it will cut through the metal fine. But before cutting anything make sure your not going to hit something inside the door (like the window channel or winder etc).
    Once thats done, mark out your cutout, drill a hole for the jigsaw blade to go through and hang on while you try and stick to your texta mark lol, best way is to brace yourself against the sill panel and with your knee push on the door so it stays fully open.
  15. #15
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
  16. #16
    Luke0011 is offline Car Audio Installer
    VZ Berlina 2005
    Jan 2007
    Woah woah, jigsaw blades, angle grinders.... are you guys serious.... the metal inside the door trim is not much stronger than an aluminium can. Tin snips gives you a nice clean round hole done in about 40 seconds, and there was never a factory hole in any VB VC VH VK VL door.
    Just remember the 15cm by 15cm trick and you clear the double metal skin and are able to wind down your windows.
  17. #17
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
  18. #18
    Mar 2009
    Cairns White Rock
    Quote Originally Posted by VKCOMMO View Post
    15x15 trick, whats that???
    15 cm up, 15 cm accross, when looking at the left corner of the drivers door trim, and obviously the right corner for the passenger side. Luke actually explained this to you already.>best way to install speakers in vk door
    You need to listen to what people are saying...
  19. #19
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    thanks, i forgot about the other threads and this one as well as ive been pre-occupied at looking for cheap BMW wreckers
  1. Vp Calais Parts, Front Driver Side Door and Front Quarter Panel
    By coops_23 in forum Swap / Wanted to Buy / Trade
    Last Post: 16-05-2008, 09:34 PM
  2. Replacement Speakers front doors VX Commodore 2001. 5.25", 6" or 6.5"
    By antis0cial in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-12-2007, 04:03 PM
  3. "VK" swapping LH front seat to RH front rails
    By VK-Berlina5.0 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-03-2007, 04:04 PM
  4. VT II Acclaim wagon door and tail gate "creaks" when going over bumps.
    By muso in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-08-2006, 11:11 AM
  5. Will 6.5" Jaycar splits fit in VT front door?
    By Muttley in forum Car Audio
    Last Post: 02-10-2005, 04:43 AM
