Results 1 to 7 of 7
Thread: Vr front speakers in doors
    calebsnodgrass is offline Not defected... yet
    VR Commodore Executive, Series I, 3.8L
    Mar 2009
    Kadina
    Default Vr front speakers in doors
    Hey everyone
    im about to buy a pair of kenwood 6.5inch speakers 240watt
    now im not looking for someone to say "get these speakers they are better" i want these ones lol
    anyway, how do you install the speakers in the front passenger and driver side doors
    all help is appreciated
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    I'm not having a go, but if your knowledge is that limited, that you can't look at a door trim, and figure out how it would come off, then i can only suggest that you have someone do it for you. Because if your not at all confident with the simpler side of the instalation, then your most likely to run into further trouble with things like running wires, polarity ect...I'm not saying don't have a go and learn, but replacing stock speakers in a VR is a job that if your patient enough, you should be able to complete yourself no worries, even if it's your first ever experience with car audio.
    Mar 2009
    Kadina
    Quote Originally Posted by HoldenCommodoreVP View Post
    No thats fine i can do it i just didnt want to take the panel off and find out i have broken something.
    I have changed the back speakers my self, i know not very challenging but I did it.
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Stressball's Avatar
    Stressball is offline Rolling on 4 again :D
    Mitsubishi Triton
    Oct 2005
    SE QLD
    Use a flat blade driver to prise of the inner door handle cover, remove both screws inside.
    Remove one screw on the front-bottom corner of the speaker pod, and 2 others along the bottom of the door trim skirting.
    Use a very, very fine flat blade to prise out the little red tabs in the door locks; you will quite possibly crack the tabs or the plastic surround, someone may have an idea how to do it an easier way. Remove the tab, pull the grey plastic surround out and remove that screw as well.
    Remove the two or 3 visible screws in the door A/C vents, you may also have to pull out the top vent to get to a screw holding the whole section to the door. Take care of the other 3 first, and if the section still won't budge, investigate further.
    Once all these screws are out, you should be able to pull the door trim straight off.
    Oh and also, 6.5" speakers will not fit very well without cutting the plastic sheeting that is underneath the door trim, and depending on the size of the magnet, they may not fit inside the door frame; the magnet could rest against a metal piece behind the speaker hole/ If this is the case, do everything you can to mount it extended from the door frame, but make sure you put something between the magnet and the metalwork to stop it from vibrating, it will drive you insane otherwise. Personally I would suggest you find some 6" speakers instead, but if your mind is made up, your mind is made up
    Research your wires and polaritys before you connect anything. Check the wiring diagrams for your speakers, check the wiring diagrams for you cars, and make sure you get them right. Solder/connect the terminals, whichever you need to do, and make sure the terminals don't touch the door frame. Ordinarily this would not be a problem, but if you get stuck mounting the speakers not flush with the hole, the terminals may line up perfectly to touch the door frame. Use heatshrink to cover the terminals, and of course, do the same to any soldering joints anywhere. Make sure you leave no exposed wires anywhere they can touch anything else.
    I hope your speakers are not splits; they may sound way better, but you will struggle like a mofo trying to run tweeter wires through the rubber door grommet if they're inline crossovers.
    Mar 2009
    Cairns White Rock
    OP has a VR exec, so he's going to have to remove his window winders also. I strongly suggest you upgrade the speaker cable while your there, i wouldn't use the original wiring. If they are spits, there's no need to run tweeter wire through the grommet, the wire on your tweeters will only be short anyway, you can run the same size cable to them, as you would with your speakers, through the same grommet, and you will find any given number of holes in the face of the door, which you can run the wire back out, to re-connect to the tweeters. Also makes it particulary easy if you plan to mount the tweeters on the back or the mirror surround covers..
    Stressball's Avatar
    Mitsubishi Triton
    Oct 2005
    SE QLD
    Forgot about the windows winders, I've got electrics O:-)
    In the case of my speakers w/ inline crossovers, the speakers have 4 terminals; pos + neg to the headunit, and pos + neg to the tweeters, tweeters drawing through speakers and crossover between the two. If the tweeters are this style, they will need to be connected to the door speaker one way or another. As you say though, mirror surround would make things easy also.
  1. Best Value 6" Speakers for front doors?
    By struggo in forum Car Audio
    Last Post: 01-10-2010, 08:45 PM
  2. Fitting speakers in VT front Doors
    By JoeFish in forum Car Audio
    Last Post: 28-12-2008, 09:35 PM
  3. Installing 6 1/2" Speakers in VK Front Doors
    By RayRay07 in forum Car Audio
    Last Post: 30-04-2008, 10:02 PM
  4. Replies: 4
    Last Post: 28-12-2006, 04:48 PM
  5. Best Value 6" Speakers for front doors?
    By struggo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-12-2006, 11:02 AM
