Results 1 to 4 of 4
Thread: Rear speaker wiring problems
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Default Rear speaker wiring problems
    I want to run 6x9`s in my VX so I want to cut the rear door wires and patch wires to the parcel shelf but the colours are different in the mid section that runs along the door sills, if I have confused anyone this is what I mean the left (drivers) rear speaker is brown/black & yellow/blue it leaves the head unit like this and comes out at the speaker hole like this but somewhere in the middle it has different colours as there is a loom connection behind the lower drivers seat belt bolt (on the pillar) just before it goes out to the door in the weather proof rubber seal, there is a little bung here and I took it off and shone a torch in there and saw no brown/black yellow/blue go in but on the other side they appear but I cant get a good view to see what the other colours are that line up and turn into them because of the amount of other wires and limited view, anyone help.
    undar8ed1's Avatar
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    F##k it I`ll just run wires from the head unit to them I thought the other way I tried would save me time but it just wasted it.
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    If you remove the sill panels just in front of the seat belt bolts you'll see the main wiring loom. In there will be your rear speaker wires. Ive done this a few times and never had a problem.
    I cant imagine they changed colours half way along the loom?
    150db in a commodore =
    undar8ed1's Avatar
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Quote Originally Posted by holdenboy View Post
    Well I`d start imaginig it because it happend, I checked every wire.
  1. vt rear electric windows & rear speaker problems
    By dcjacko in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-03-2009, 05:40 AM
  2. VN Rear Speaker Wiring
    By Rustyone in forum Car Audio
    Last Post: 02-10-2006, 11:16 PM
  3. Rear Speaker Wiring Question
    By azzfox in forum Car Audio
    Last Post: 25-01-2006, 08:34 PM
  4. Sv6 rear speaker wiring
    By suppy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-09-2005, 10:15 PM
  5. Where does the Rear Speaker Wiring go?
    By Darkwander in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-03-2005, 04:25 PM
