Results 1 to 14 of 14
Thread: splits in a VZ
    Feb 2008
    Default splits in a VZ
    ok..I am putting a set of 6.5 inch splits in the front of my VZ.. i am up to putting the tweeters in.. i dont really think i can fit them where the original ones go any ideas??
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    I just stuck mine with sticky-backed velcro to the tweeter/demister covers, although in the sun they have started to move and made a sticky mess :P.
    I think the best way would be to make a simple mount that will slot in between the tweeter cover and the A pillar.
    Ve SS
    Nov 2009
    When i had mine i put the them just near the air con vents on the door trim and angled them towards the ear level
    before if cut anything on the door trim i did a dry run and used blu tak to make sure that i all looked ok
    worked fine and sounded great for me
    VesperZ's Avatar
    VesperZ is offline 2005 Holden VZ Berlina
    VZ Berlina
    Jul 2009
    Sydney, NSW
    Hey arrow,
    Actually they do fit where the original ones are, all I did with mine is remove the original tweeters from the brackets they are mounted to, and screwed my new ones to the brackets, then mounted them back in. Couldn't have asked for a cleaner install.
    VK
    Jul 2004
    Quote Originally Posted by H0LD3N View Post
    Hey arrow,
    This.
    Only downside is the angling is a bit off, but good enough for a standard install.
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    I've used the standard mount, as above re-use the stock bracket if you do this.
    I've also tried the black plastic triangular cover on the door behind the side mirrors, you'll need to use a hole saw to cut out a mount and run a wire if you do that. Less stealth, but better sound staging I found.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    VesperZ's Avatar
    VZ Berlina
    Jul 2009
    Sydney, NSW
    Quote Originally Posted by danja View Post
    Yea I did that in my old VT, wasn't really happy with using the triangular cover install only because it's curved and if you try and put a tweeter in there then it doesn't sit flush unless you do some fibreglass magic. You're right, it does sound better from there, but all the same requires alot more fabrication if you want it to look good.
    Feb 2008
    thanks for the help guys i will give it a crack on the weekend and let you know how i go!
    danja's Avatar
    Jan 2006
    I got around that by mounting one edge flush, then glued and trimmed some black fabric around the other edge till it was perfectly flush. Was pretty easy, and looked very professional if I do say so myself
    VZS-Ute06
    Aug 2006
    Western Vic
    Thumbs up
    G'day guys my tweets sound sweet here
    Tweeter postitioning
    VZ-Rob
    98 Ron Powerchip: CAI: SuperLows: GTS Swaybars: Tinted: SS Grille: SS Vents: SS 2:25 Twin Exhaust: ASR Audio:
    danja's Avatar
    Jan 2006
    Quote Originally Posted by VZ-Rob View Post
    Looks very nice. My only reservations about doing that is that If I want to take them out to sell etc I have to replace the door trims (expensive), whereas it's no big deal to get a couple of plastic triangle panel things (cheap).
    Nice job though, bet they sound great.
    VesperZ's Avatar
    VZ Berlina
    Jul 2009
    Sydney, NSW
    Yes I was about to say the same as danja, hence why I mounted mine under where the original tweeters were, meaning I don't have to replace anything But I must say it is very much the ideal location to have tweeters and is a very clean install
    "Nonsense, this is the kind of coverings what we humans wear at this period of time. I'm quite sure of it."
    See my ride here
    VP Executive S2, VL 5sp Berlina Wagon
    May 2008
    Down South, Adelaide
    How do you get the panel off to mount them where the original tweeters are? Im needing to mount mine somewhere and im gonna try there but have no idea how to get them off
    Sleeper Wagon - In the Build
    VP Executive series 2
    Check out My Ride
    Current Mods
    Widened S/C CAI, 2.5" exhaust, Advance headers, no bellmouth, 17" VY SS, Foamy Tune
    Future Mods
    New Car
    Wanted
    MONEY!!!
    VS Ute Series 2
    Aug 2009
    Wagga Wagga
    i put my tweeters in the top air vent on the doors, they point directly at you and pretty easy to put in there. Just had to glue them in and i love them there
  1. An amp to run my splits?
    By acarmody in forum Car Audio
    Last Post: 22-01-2009, 12:17 AM
  2. Splits into a vs
    By mattgreen in forum Car Audio
    Last Post: 21-01-2008, 04:01 PM
  3. VT splits :?
    By Timzo in forum Car Audio
    Last Post: 16-06-2006, 10:26 AM
  4. splits
    By VL-187 in forum Car Audio
    Last Post: 06-12-2005, 08:28 PM
  5. Splits
    By mrc25381 in forum Car Audio
    Last Post: 21-08-2005, 09:42 PM
