Results 1 to 10 of 10
Thread: Double Din in a VS
    Vy Sv8
    Jun 2009
    Default Double Din in a VS
    Simple question.
    Can it be done, if so is there a replacement console I can buy??
    Or do I have to mod it myself???
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    I've seen it done, but its a lot of work and it all has to be done yourself...or pay someone. There's no replacement console you can buy off the shelf
    tr3nt's Avatar
    tr3nt is offline trent was 'ere
    VP Calais International 5L
    Sep 2003
    Melbourne, AU
    If you're good with Bog, and a blade of some sort, it can be achieved
    Quote Originally Posted by hakhawk View Post
    if you pay for fuel, ill drive up and drive you around in the bmw. assuming your(hopefully hot) date rides shotgun, and you get the boot, dont worry, its well ventilated if ur dates not so, you can share the boot
    sycvs is offline commo for life
    vs executive
    Jul 2009
    phillip island
    i did it pain in the arse and it sticks out to much the heater box is in the way
    Vy Sv8
    Jun 2009
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Heater box??? If you want a double DIN bad enough you dont need a heater
    150db in a commodore =
    lastlegend's Avatar
    lastlegend is offline Phantom VY SS
    2003 Black VY SS + 1999 Silver VT Olympic Sedan
    Sep 2008
    Thorneside QLD
    Hi mate,
    Yeah it can be done, I put a triple DIN into my old VR a few years back when I worked at Straithfield car radios in Coffs Harbour. we joked about doing it and in the end the installer said lets try.
    The center dash was cut apart and we fitted a Kenwood Double Din + a single din graphic under it, the re-design called for the Heater box to be modified by cuting the front section out and glueing new panels to cover the cut away section. We also removed the centre cross panel which housed the little red flashing ligh.
    Once fitted the unit sat flush with centre console and worked great, it powered three high end Kenwood amps. 1 x 2CH to run the front 5" & 6" splits, 1 x 2CH to run 6" & 8" rears and a Mono to run 3 x 12" MTX 8000 series subs.
    If you would like some images on the install of the H/U & Graphic just let me know.
    Quote Originally Posted by M01ST View Post
    Simple question.
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    Quote Originally Posted by lastlegend View Post
    Hi mate,
    I think we would all like some images.
    lastlegend's Avatar
    Sep 2008
    Thorneside QLD
    No worries, I will dig out the cd tonight and upload some images of the install ASAP
    VS V6 Exec
    Dec 2009
    Narre Warren, VIC
    Yeah I'd like to see some too. That sounds rather different.
  1. best double din DVD for under $300
    By Razor- in forum Car Audio
    Last Post: 13-08-2009, 12:38 AM
  2. Double Din
    By Kuka in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-04-2009, 09:34 PM
  3. VS double DIN
    By Niggadore in forum Car Audio
    Last Post: 25-10-2008, 12:14 PM
  4. Best double din under $500
    By Gero SV6 in forum Car Audio
    Last Post: 15-10-2008, 09:20 PM
  5. VS Double Din??
    By ezytarget in forum Car Audio
    Last Post: 10-04-2005, 11:58 PM
