Hi, I am wanting to replace my rear door speakers on each side. I could get it done by the car audio guy at JB but I don't want to spend extra money if I don't have to.
I have taken off all the visible bolts on both rear doors but it doesn't want to come off. I'm guessing there's more I need to do. What would I need to do to remove them?
Please help,
xdx
If it has a windo winder you will need to remove this by unclipping the u clip in behind it. usually a piece of string is the easiest way.
Also, the door locks have to come off by pulling out the red tab and pull the lock up, usually there is a screw behind this aswell
Hope this helps, I dont have a VT but all commodores were built very similar. im sure you'll find some more info with a little bit more research
Daz
PHOEN1X - 06 VZ SV6
Ok lets see if I can remember. Door locks off, little red tab must be flicked out, use tiny flathead screwdriver. Door handle taken off. There is also another screw behind door handle. Window winder removed. Once all door screws are removed, door lifts UP.
Ronald Reagan (1986)
Im pretty sure theres also plastic clips?
150db in a commodore =
thanks for the advice
