i need help to find out the wire colours for the speakers for the front and and also if the the utes have then the rear speakers. i am installing a sub and amp. also i need the find out the best location to connect a amp remote wire. thanks.
*Remove drivers side centre console panel
*You'll see a black plug on the "side" of the stereo, this is your speaker outputs.
Left Front - Grey(-) Brown(+)
Right Front - Dark green (-) Light green/Black(+)
Left Rear - Yellow/Red(-) Brown(+)
Right Rear - Light Blue(-) Dark Blue(+)
*Also, just below the black plug is a white plug with 3 wires in it and not connected to anything, this is a good source for accessories (Brown / Yellow wire) .
The utes do have the rear speaker wires at the head-unit, not sure where they go but. You will need to activate the rear speaker outputs, heres a quick rundown of how to activate them:
*Firstly ign "On" & radio "Off"
*Then, hold 'track right', 'disc right' & radio 'on' simultaniously for about 8-10 seconds, you'll then get the service menu. In here you can activate either 2 channel or 4/5 channel speakers, 12/24 hr clock & a few other things.
* After doing this you can access fader "Front & Rear" in the main menu.
Just FYI, all of this info came from JC with a search![]()
150db in a commodore =
thanks heaps for your help.
No problems guys......just remember next time to do a search and it should come up, ive posted this info before for others![]()
