Results 1 to 18 of 18
Thread: vs stock speakers
    VUII SS
    Mar 2008
    Default vs stock speakers
    Just wondering what speakers kind of speakers a vs has? one of my speakers is not working and I am thinking I might try and replace it, but seeing as everything else is stock, I would probably try and replace it with a stock item.
    CHeers.
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Subaru Liberty
    Feb 2007
    VR and VS commodores have 6" splits in the front (mid-range/mid-bass in the door pod, tweeter in the dash where the A-pillar meets the dash) and 6" coaxials in the rear.
    <<<< The information went data way! >>>>
    2005 VZ SV6
    Jun 2009
    Australian Crapital Territory
    When I got my VS I was actually really surprised how good the stock stezza was. Im using an Aftermarket HU and Sub with Stock speakers and I'm happy with it for the moment till I allocate some more dosh to the Stezza Good luck, like CommoVP said, prob just post in the WTB section
    Mar 2009
    Cairns White Rock
    VUII SS
    Mar 2008
    VTSS350 is offline Blown VT LS1 450rwhp
    VTLS1
    Oct 2005
    Quote Originally Posted by Maxxiz View Post
    Your joking right?? You should put your hearing aid in more often!!
    The stock speakers in all commodores are garbage.
    I just purchased a brand new SV6 sportswagon and the speakers only lasted 1/2 a day before they were replaced with a Focal system.
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    VUII SS
    Mar 2008
    Quote Originally Posted by VTSS350 View Post
    I think garbage is a bit extreme... the stock speakers I had in my old VX were more than adequate, especially now compared to the ones in a VS! I guess it depends what you listen to and how you listen to it...
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    It also depends on what you call adequate too......not having a go or anything, so dont take offence.
    Some people think 5w 4" dual cone speakers are fine for a car stereo system, while others wont put anything less than a few thousand watts and a few thousand dollars worth of speakers in their car.
    My point is, sound is very subjective. If youre happy with the sound, thats all that matters
    150db in a commodore =
    VUII SS
    Mar 2008
    no offence taken.
    its true, peoples needs vary, and some people only need a stock system, others need their ears to bleed!
    love to upgrade my system but i cant afford it!!
    VS commodore
    Dec 2009
    I have a VS too and am trying to find a way of mounting some 6'' by 9''s in the back, it has proved to be a bit a mission. Any ideas would be awesome!!!
    VS V6 Exec
    Dec 2009
    Narre Warren, VIC
    Mounting? Aren't the holes already marked out in the parcel shelf? If they're not, look in from the boot, mark out enough of a hole for the back of the speaker and a little more to fit and then cut.. Mine came with them prefitted.. Only ever had to cut speakers out of a few old holdens and fords. Get some spacers from autobahn for the speaker to connect to.. wiring etc and voila!!!
    Mar 2009
    Cairns White Rock
    Quote Originally Posted by K Dub View Post
    The stock rear holes in a VS were only designed for a 6 inch speaker. The only way to fit a 6x9, is to use a spacer (such as this one) APF69HBL : 1 Pair 6x9" (152mmx228mm) Black Vinyl Fibreglass Speaker spacers :: Speakers
    You'll need to mount them going length way's aswell. This about the only way you'll be able to mount them, without cutting anything anything.
  15. #15
    VS dream is offline Lets go cruising!
    VS Executvie SeriesII
    Oct 2010
    Frankston, Victoria
  16. #16
    VS Berlina S2
    Aug 2010
    Blown VS Calais !!
    Jan 2005
    Kalgoorlie WA
    Im 100% sure there not 6.5" in VS , if you want sick by nines then your going to have to remove the steal bridge te speaker mounts to thats under the moulded shelf.
    Right click save as . .
  18. #18
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    Quote Originally Posted by Tony. View Post
    Correct me if I'm wrong, but the VX speakers I've seen have been exactly the same as VS ones. I think you might have imagined yourself an improvement there.
    EDIT: Oh wait, except for the "maestro" stereo or whatever that was...probably still exactly the same though
LinkBacks (?)
  1. Stock Speakers SV6
    By Kye in forum VE Holden Commodore (2006 - ?)
    Last Post: 12-10-2009, 05:16 PM
  2. How big are the stock speakers in a vs?
    By vs_commy5506 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-07-2009, 11:55 PM
  3. how big are stock vz speakers
    By schteven in forum Car Audio
    Last Post: 01-08-2008, 02:15 PM
  4. Stock VY speakers
    By markwid in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-09-2006, 07:56 AM
  5. Amp / Speakers with Stock VY HU
    By Darren in forum Car Audio
    Last Post: 31-07-2005, 12:30 PM
