Results 1 to 13 of 13
Thread: constant power ??
    vr 5 speed wagon
    Dec 2009
    Alice Springs
    Default constant power ??
    hi could someone please help me im tryin to work out how to run constant power to my sterio so i can have the car off n just power up the stezza n listen to tunes ?? can someoine help me plz its vr
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    vr 5 speed wagon
    Dec 2009
    Alice Springs
    yeah but how do i do that though i can wire the rest just not sure how to do that part
    strgas's Avatar
    Oct 2009
    run a wire from the positive terminal thru the engine bay thru the firewall and connect it to your stereo power supply wire dont forget a fuse at the battery , or use the live wire at the ignition switch loom ??? if in doubt have a auto elec wiring the power side for you ...
    vr 5 speed wagon
    Dec 2009
    Alice Springs
    oh yeah i have an old amp power wire there with a fuse in it that runs straight inside i can just hook that up th it n dont have to earth it out or does it just earth though the sterio .
    strgas's Avatar
    Oct 2009
    connect it to earth without the stereo in line and it will short out , connect to your stereo power wire and the stereo earth wire to earth ??? simple as that
    vr 5 speed wagon
    Dec 2009
    Alice Springs
    oh sweet sorry to b a pain just wanna make sure before i fry shit costs to much lol cheers
    strgas's Avatar
    Oct 2009
    always better to ask questions first and look silly than go ahead and stuff it up completely
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    I would recommend just joining the yellow and red wires together on the back of the head-unit, its simplier and less dangerous.
    May i ask why you would want to hook it straight up to permanent power? This is one of the reasons why the accessoires switch in the ignition was made.
    150db in a commodore =
  10. Default
    i would personally find it very annoying to have to turn off the headunit manually every time i switched off the car.
    there's a thread on here somewhere where a guy wired up the acc wire to a relay so the headunit stayed on until the doors were opened. that's about as far as i'd go
    Quote Originally Posted by zai View Post
    I am not sutpid
    VY SS
    Jun 2006
    Albany
    how about using the constant feed from behind the headunit and use a switch which is wired to constant and accessories so when you flick the switch on with the keys out you can listen to your cd player
  12. Default
    Quote Originally Posted by axemurderer101 View Post
    what's the difference between that and using the on/off button on the headunit though?
    I am not sutpid
    2002 VX II Acclaim
    Aug 2008
    I'd just hook up a switch that bridges accessory power to 12v constant. When switch is off, it will work just like its supposed to (with key in acc/ign position), when switch is turned on, stereo will be working regardless.
  1. no constant power wire in vx??
    By JT090 in forum Car Audio
    Last Post: 30-12-2011, 03:30 PM
  2. Constant Power to power window switch
    By stockies in forum Electrical Wiring / Questions
    Last Post: 02-05-2009, 08:14 PM
  3. constant power supply for head unit not working
    By ShIbBy_industries in forum Electrical Wiring / Questions
    Last Post: 18-06-2008, 09:10 PM
  4. constant power supply not working
    By ShIbBy_industries in forum Car Audio
    Last Post: 18-06-2008, 08:18 PM
  5. VR needs constant revival :(
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2006, 12:34 PM
